Date/Time: Wed, 27 Nov 2024 16:50:45 +0000
How to keep OCO's Independentent
View Count: 267
[2023-07-17 09:39:39]
User933497 - Posts: 12
I have an OCO for one contract with a simple profit target and stop. It works fine.
However, if I add another contract with the same OCO, Sierra adds to the original stop and profit targets (no matter where price is). So now I have "2" contracts with the same profit and stop target.
I want to keep those separate so I can adjust them individually. How can I do that?
[2023-07-17 10:03:52]
Sierra_Chart Engineering - Posts: 17195
Make sure this option is disabled on the Trade Window:
Attached Orders: Scaling In
[2023-07-17 13:58:09]
Ok, I unchecked the support scale in/out settings in the order window. That works.
However, every time I switch OCO's, they come back. I looked and can't see how to stop this globally?
[2023-07-17 14:34:51]
We do not understand what you mean by this:
Date Time Of Last Edit: 2023-07-17 14:35:05
[2023-07-18 10:13:18]
Say I'm using OCO #1 to place the trade with. I have removed the checkmarks for scale in/scale in the order settings.
Now, for the next trade, if I switch to OCO #2, the scale in/scale out checkmarks reappear and I have to remove them again.
Every time I switch to a different OCO, the scale in/scale out checkmarks are back. I do not want them and have to uncheck them every time I switch to a different OCO.
[2023-07-18 13:33:36]
John - SC Support - Posts: 36322
If you are referring to "Trade Configurations", then you would need to resave these with the Scaling In/Out options set as you want them to be for that configuration. Refer to the following:
Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations
