Date/Time: Wed, 27 Nov 2024 17:38:19 +0000
Buy/sell stop order button
View Count: 293
[2023-07-16 19:16:04] |
Xiongl80 - Posts: 6 |
Is there a way to add a button (whether to the Chart Trader or the Control Bar) that would allow me to enter a buy/sell stop order a certain amount of ticks above/below the last bar's high/low, respectively? For example, once a bar closes, I could hit the button and a buy stop order would be set just above the last bar's high plus a certain amount of ticks that I would specify.
[2023-07-17 18:10:16] |
John - SC Support - Posts: 36329 |
You can try to see if you can do this in the Spreadsheet Trading System. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading Otherwise you would have to create a custom study to do what you want. Refer to the following: Automated Trading From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
