Date/Time: Tue, 26 Nov 2024 15:49:23 +0000
[User Discussion] - "Enable Order Allocation" and some other settings not getting saved.
View Count: 513
[2023-07-16 10:23:33] |
ProfitableTrader - Posts: 22 |
I have multiple accounts under one login for which I have order allocation set under specific DOMS. However, the option "Enable order allocation to trade accounts" gets reset each time and I have to manually enable it for the session. This did not used to be a problem before, not sure why that option is no longer getting saved. Looks like the issue may not be limited to just order allocation. Selected "Disable Trade activity log", saved and exited the app. When Sierra Chart started, the "Disable Trade Activity Log" was no longer selected and had to be manually selected again. Also made changes to this: Global Settings -> Graphics Setting -> Other Then selected "Use OpenGL for Graphics." This setting also does not get saved once Sierra chart is closed and restarted. Which configuration file saves these? I have it set to open my default chartbook with 1-2 DOMS under Global Settings --> General Settings --> Startup -> Open Files on Startup. Do I need to add some other config files that have the settings above saved at startup? Date Time Of Last Edit: 2023-07-16 10:49:33
[2023-07-17 04:10:47] |
user_xyz - Posts: 416 |
I know "Enable Order Allocation To Trade Accounts" now has an option to save with latest version, search forum for thread. Not sure about the others.
[2023-07-17 09:36:57] |
Where is this option located?
[2023-11-14 15:49:48] |
User316362 - Posts: 210 |
You can set it under General Trade Settings. Set "Disable Order Allocation to Trade Accounts on Chartbook Opening"....set it to "no" if you want to preserve setting across restarts
Date Time Of Last Edit: 2023-11-14 16:09:18
