Date/Time: Wed, 27 Nov 2024 17:28:12 +0000
export Tick intraday data to CSV for certain date range
View Count: 408
[2023-07-16 02:31:25]
ronvle - Posts: 4
hello support,
I played around with "Days to load", "Dates range" in Chart->Chart Settings, but still couldn't figure to export TICK intraday data for a period of 5 days in the past that I can randomly pick, any help is appreciated!
The data that got exported has dates out of the range I specified.
[2023-07-17 17:58:08]
John - SC Support - Posts: 36329
Set up the chart the way you want it then select "Edit >> Export Bar Data to Text File". Refer to the following:
Edit Menu: Edit >> Export Bar Data to Text File
[2023-07-17 20:03:15]
Sierra_Chart Engineering - Posts: 17195
Also refer to this section here:
Time and Sales Window: Viewing Time and Sales on a Spreadsheet
