Date/Time: Wed, 27 Nov 2024 17:43:20 +0000
can't change chart settings > date range in file
View Count: 387
[2023-07-16 01:19:56] |
User425645 - Posts: 113 |
I can't change the chart setting "date range in file from". When I edit it, it just goes back to the previous value. How do I stop this from happening?
[2023-07-17 17:55:24] |
John - SC Support - Posts: 36329 |
It depends on what symbol you are trying to do this for and how far back you are trying to set the date to. Most likely you are doing this on a Futures contract, which have a limited lifetime, therefore you can only go back so far. In order to see the data further back, you would need to use a Continuous Futures Contract Chart. Refer to the information here: Continuous Futures Contract Charts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
