Date/Time: Wed, 27 Nov 2024 19:39:13 +0000
Indicator Switch In The Chart Window
View Count: 234
[2023-07-14 16:48:25] |
novaxt123 - Posts: 42 |
Hello I see in other trading platforms (Agena Trader, Trading View) that indicators can be switched on and off directly in the chart. Does Sierra Chart have this option as well? If not, do you know a programmer who can do it or does it already exist, for example at Future.IO? |
[2023-07-14 18:39:37] |
John - SC Support - Posts: 36343 |
Refer to the following: Chart Studies: Hiding and Showing Study Directly from Chart And also the following: Chart Studies: Quick Access to Study Settings Also, you can use Study Collections to quickly change between a particular group of studies. Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
