Date/Time: Wed, 27 Nov 2024 19:41:48 +0000
Live data not appearing on stocks
View Count: 358
[2023-07-14 13:14:40] |
Shawn J - Posts: 32 |
Good morning. It seems like my data is not showing this morning. when I open my charts, there is the blue message "Downloading Historical Data." It will switch to the red "Download Failed" message and then switch back to the blue message.
[2023-07-14 13:49:32] |
Sierra_Chart Engineering - Posts: 17198 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-14 14:09:04] |
Software version: 2523 64-bit | 2023-07-14 10:07:21.880 Primary Thread ID: 10228 | 2023-07-14 10:07:21.880 Usage end date: 2023-07-24 | 2023-07-14 10:07:21.880 Enabled for: Advanced Features 2. | 2023-07-14 10:07:21.880 Enabled for: Sierra Chart Historical Data Service. | 2023-07-14 10:07:21.880 Enabled for: Denali Real-Time Exchange Data Feed. | 2023-07-14 10:07:21.880 Enabled for: Delayed Denali Exchange Data Feed. | 2023-07-14 10:07:21.880 Enabled for exchange2: fairx_exchange.data | 2023-07-14 10:07:21.880 Enabled for exchange2: NASDAQ TotalView US stock data | 2023-07-14 10:07:21.880 Enabled for exchange2: NASDAQ Global Indexes | 2023-07-14 10:07:21.880 Allow Support for Sierra Chart Data Feeds is enabled. | 2023-07-14 10:07:21.880 Current selected Data/Trading service: SC Data - All Services | 2023-07-14 10:07:21.880 Custom symbol settings values: enabled | 2023-07-14 10:07:21.880 Chart Update Interval: 500 | 2023-07-14 10:07:21.880 Intraday Data Storage Time Unit: 0 | 2023-07-14 10:07:21.880 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2023-07-14 10:07:21.880 2023-07-14 14:07:21 Local computer time in UTC | 2023-07-14 10:07:21.880 2023-07-14 10:07:21 Local computer time in SC Time Zone | 2023-07-14 10:07:21.880 2023-07-14 13:59:31 Server time in UTC | 2023-07-14 10:07:21.880 Local computer UTC time and Server UTC time difference: 1 seconds. | 2023-07-14 10:07:21.880 Program path: C:\SierraChart\ | 2023-07-14 10:07:21.880 Data Files path: C:\SierraChart\Data\ | 2023-07-14 10:07:21.880 OS Version Number: 10.0 | 2023-07-14 10:07:21.880 Locale Setting: C | 2023-07-14 10:07:21.880 DLLs: AmyStackArrow2_64.dll, AmyStackArrow_64.dll, AmyStudies2_64.dll, AmyStudies3_64.dll, AmyStudies5_64.dll, AmyStudies6.5_64.dll, AmyStudies6_64.dll, AmyStudies_64.dll, delta_64.dll, DOMtape2_64.dll, DOMtape_64.dll, DOMTest_64.dll, Jigsawtape_64.dll, RecentTradedDelta_64.dll, TicinoMathV3.0_2151_64.dll, TicinoSuite_64.dll, UserContributedStudies_64.dll, VolMultButtons.dll, VolMultiplier_64.dll, VolumeeMultiplier.dll | 2023-07-14 10:07:21.880 Allowed protected custom studies: TicinoSuite, zyp_app | 2023-07-14 10:07:21.880 Crash reporter started: true | 2023-07-14 10:07:21.880 Enabling compression for file: C:\SierraChart\Data\PFRX-NQTV.scid. This may take a while. | 2023-07-14 10:07:33.755 File compression enabled. C:\SierraChart\Data\PFRX-NQTV.scid. CompressionState=0 | 2023-07-14 10:07:33.755 PFRX-NQTV 5 Min #1 | Reloading chart. | 2023-07-14 10:07:33.755 PFRX-NQTV 5 Min #1 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\PFRX-NQTV.scid | 2023-07-14 10:07:33.760 Mapping PFRX-NQTV to PFRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:07:34.264 Denali Data Feed | Starting real-time market data updates for: PFRX-NQTV (PFRX-NQTV). ID: 106 Service code: nasdaq_exchange.data | 2023-07-14 10:07:34.264 Denali Data Feed | Requesting security definition data for: PFRX-NQTV (PFRX-NQTV). ID: 106 | 2023-07-14 10:07:34.264 Added historical Intraday data request for PFRX-NQTV to the queue. | 2023-07-14 10:07:34.264 Intraday data recording state for symbol PFRX-NQTV is set to download 'Pending'. | 2023-07-14 10:07:34.264 Triggering next historical data download in queue. | 2023-07-14 10:07:34.264 File >> Disconnect selected. | 2023-07-14 10:07:45.923 Denali Data Feed | Waiting for socket receive thread to end | 2023-07-14 10:07:45.923 DTC Client socket (1) | CloseSocket call. | 2023-07-14 10:07:45.923 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2023-07-14 10:07:45.923 DTC Client socket (1) | Max send buffer size during socket life: 11070 | 2023-07-14 10:07:45.923 Denali Data Feed | Disconnected from the server. | 2023-07-14 10:07:45.923 DTC Client socket (1) | Write in progress. Shutdown being delayed. PendingSize=0 | 2023-07-14 10:07:45.923 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2023-07-14 10:07:45.923 DTC Client socket (4) | CloseSocket call. | 2023-07-14 10:07:45.923 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2023-07-14 10:07:45.923 SC DTC Delayed Exchange Data | Disconnected from the server. | 2023-07-14 10:07:45.923 SC DTC Delayed Exchange Data | Waiting for socket receive thread to end | 2023-07-14 10:07:45.923 DTC Client socket (5) | CloseSocket call. | 2023-07-14 10:07:45.924 DTC Client socket (5) | Shutdown started. Waiting for graceful close. | 2023-07-14 10:07:45.924 SC DTC Delayed Exchange Data | Disconnected from the server. | 2023-07-14 10:07:45.924 SC Data - All Services | Disconnected. | 2023-07-14 10:07:45.924 Canceling queued historical data download request for PFRX-NQTV Intraday data. | 2023-07-14 10:07:45.924 Removing historical data download ID 4. | 2023-07-14 10:07:45.924 Real-time Intraday chart data file updates started for PFRX-NQTV | 2023-07-14 10:07:45.924 Intraday chart data file opened for PFRX-NQTV | 2023-07-14 10:07:45.924 HD Request # 9 | Active download canceled. | 2023-07-14 10:07:45.924 Historical data download thread signaled to stop. | 2023-07-14 10:07:45.924 Socket (2) | CloseSocket call. | 2023-07-14 10:07:45.924 Socket (2) | Write in progress. Shutdown being delayed. PendingSize=0 | 2023-07-14 10:07:45.924 HD Request # 9 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for PRFX-NQTV | 2023-07-14 10:07:45.924 HD Request # 9 | Completion time: 37s. | 2023-07-14 10:07:45.924 HD Request # 9 | Intraday data download complete for PRFX-NQTV. Unique request ID: 3 | 2023-07-14 10:07:45.924 Removing historical data download ID 3. | 2023-07-14 10:07:45.924 Real-time Intraday chart data file updates started for PRFX-NQTV | 2023-07-14 10:07:45.924 Intraday chart data file opened for PRFX-NQTV | 2023-07-14 10:07:45.924 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2023-07-14 10:07:45.924 Triggering next historical data download in queue. | 2023-07-14 10:07:45.924 No download requests in the queue to start downloads for. | 2023-07-14 10:07:45.924 DTC Client socket (4) | Socket gracefully closed by remote side. | 2023-07-14 10:07:45.929 DTC Client socket (4) | Closed. | 2023-07-14 10:07:45.929 DTC Client socket (5) | Socket gracefully closed by remote side. | 2023-07-14 10:07:45.930 DTC Client socket (5) | Closed. | 2023-07-14 10:07:45.930 Socket (2) | Write has completed. Shutdown being performed. | 2023-07-14 10:07:47.642 Socket (2) | Shutdown started. Waiting for graceful close. | 2023-07-14 10:07:47.642 Socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-07-14 10:07:47.642 * Socket (2) | Socket gracefully closed by remote side. | 2023-07-14 10:07:47.642 Socket (2) | Closed. | 2023-07-14 10:07:47.642 DTC Client socket (1) | Write has completed. Shutdown being performed. | 2023-07-14 10:07:56.481 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2023-07-14 10:07:56.481 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2023-07-14 10:07:56.481 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2023-07-14 10:07:56.481 DTC Client socket (1) | Closed. | 2023-07-14 10:07:56.481 SC Data - All Services | Connected to server complete. | 2023-07-14 10:08:01.360 Triggering next historical data download in queue. | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. JNJ-NQTV | 2023-07-14 10:08:01.361 Mapping JNJ-NQTV to JNJ-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Using symbol data fast lookup vector | 2023-07-14 10:08:01.361 Denali Data Feed | Starting real-time market data updates for: JNJ-NQTV (JNJ-NQTV). ID: 1 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048 | 2023-07-14 10:08:01.361 Denali Data Feed | Requesting security definition data for: JNJ-NQTV (JNJ-NQTV). ID: 1 | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. JNJ-NQTV | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. BABA-NQTV | 2023-07-14 10:08:01.361 Mapping BABA-NQTV to BABA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Starting real-time market data updates for: BABA-NQTV (BABA-NQTV). ID: 2 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Requesting security definition data for: BABA-NQTV (BABA-NQTV). ID: 2 | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.361 Mapping AMZN-NQTV to AMZN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Starting real-time market data updates for: AMZN-NQTV (AMZN-NQTV). ID: 3 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Requesting security definition data for: AMZN-NQTV (AMZN-NQTV). ID: 3 | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. MESH23-CME | 2023-07-14 10:08:01.361 Mapping MESH23-CME to MESH23. Service code: cme | 2023-07-14 10:08:01.361 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESH23-CME (MESH23). ID: 4 Service code: cme | 2023-07-14 10:08:01.361 SC DTC Delayed Exchange Data | Connecting to the server ds26-2.sierracharts.com. Port 10043 | 2023-07-14 10:08:01.361 SC DTC Delayed Exchange Data | Requesting security definition data for: MESH23-CME (MESH23). ID: 4 | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. MESH23-CME | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. SPY-NQTV | 2023-07-14 10:08:01.361 Mapping SPY-NQTV to SPY-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Starting real-time market data updates for: SPY-NQTV (SPY-NQTV). ID: 5 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Requesting security definition data for: SPY-NQTV (SPY-NQTV). ID: 5 | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. MESM23-CME | 2023-07-14 10:08:01.361 Mapping MESM23-CME to MESM23. Service code: cme | 2023-07-14 10:08:01.361 SC DTC Delayed Exchange Data | Starting real-time market data updates for: MESM23-CME (MESM23). ID: 6 Service code: cme | 2023-07-14 10:08:01.361 SC DTC Delayed Exchange Data | Requesting security definition data for: MESM23-CME (MESM23). ID: 6 | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. BABA-NQTV | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. JNJ-NQTV | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. MESM23-CME | 2023-07-14 10:08:01.361 DTC Client socket (1) | Creating socket. | 2023-07-14 10:08:01.361 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.361 Mapping DIS-NQTV to DIS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.361 Denali Data Feed | Starting real-time market data updates for: DIS-NQTV (DIS-NQTV). ID: 7 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: DIS-NQTV (DIS-NQTV). ID: 7 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. JNJ-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. JPM-NQTV | 2023-07-14 10:08:01.362 Mapping JPM-NQTV to JPM-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 DTC Client socket (1) | New receive buffer size: 5242880 | 2023-07-14 10:08:01.362 DTC Client socket (1) | Connecting to IP: 38.65.8.115. | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: JPM-NQTV (JPM-NQTV). ID: 8 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: JPM-NQTV (JPM-NQTV). ID: 8 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. JNJ-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-07-14 10:08:01.362 Mapping TSLA-NQTV to TSLA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: TSLA-NQTV (TSLA-NQTV). ID: 9 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: TSLA-NQTV (TSLA-NQTV). ID: 9 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AAPL-NQTV | 2023-07-14 10:08:01.362 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 10 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 10 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. BABA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. NKE-NQTV | 2023-07-14 10:08:01.362 Mapping NKE-NQTV to NKE-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: NKE-NQTV (NKE-NQTV). ID: 11 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: NKE-NQTV (NKE-NQTV). ID: 11 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. META-NQTV | 2023-07-14 10:08:01.362 Mapping META-NQTV to META-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: META-NQTV (META-NQTV). ID: 12 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: META-NQTV (META-NQTV). ID: 12 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. JPM-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. MGRX-NQTV | 2023-07-14 10:08:01.362 Mapping MGRX-NQTV to MGRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 DTC Client socket (2) | Creating socket. | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: MGRX-NQTV (MGRX-NQTV). ID: 13 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: MGRX-NQTV (MGRX-NQTV). ID: 13 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. MGRX-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. INAB-NQTV | 2023-07-14 10:08:01.362 Mapping INAB-NQTV to INAB-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: INAB-NQTV (INAB-NQTV). ID: 14 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: INAB-NQTV (INAB-NQTV). ID: 14 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. BXRX-NQTV | 2023-07-14 10:08:01.362 DTC Client socket (2) | New receive buffer size: 5242880 | 2023-07-14 10:08:01.362 DTC Client socket (2) | Connecting to IP: 142.215.17.189. | 2023-07-14 10:08:01.362 Mapping BXRX-NQTV to BXRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: BXRX-NQTV (BXRX-NQTV). ID: 15 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: BXRX-NQTV (BXRX-NQTV). ID: 15 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. BXRX-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ATOM-NQTV | 2023-07-14 10:08:01.362 Mapping ATOM-NQTV to ATOM-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: ATOM-NQTV (ATOM-NQTV). ID: 16 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: ATOM-NQTV (ATOM-NQTV). ID: 16 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TSLA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. GSUN-NQTV | 2023-07-14 10:08:01.362 Mapping GSUN-NQTV to GSUN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: GSUN-NQTV (GSUN-NQTV). ID: 17 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: GSUN-NQTV (GSUN-NQTV). ID: 17 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SNTG-NQTV | 2023-07-14 10:08:01.362 Mapping SNTG-NQTV to SNTG-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: SNTG-NQTV (SNTG-NQTV). ID: 18 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: SNTG-NQTV (SNTG-NQTV). ID: 18 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. NVDA-NQTV | 2023-07-14 10:08:01.362 Mapping NVDA-NQTV to NVDA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: NVDA-NQTV (NVDA-NQTV). ID: 19 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: NVDA-NQTV (NVDA-NQTV). ID: 19 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.362 Mapping T-NQTV to T-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: T-NQTV (T-NQTV). ID: 20 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: T-NQTV (T-NQTV). ID: 20 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. BABA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. HOUR-NQTV | 2023-07-14 10:08:01.362 Mapping HOUR-NQTV to HOUR-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: HOUR-NQTV (HOUR-NQTV). ID: 21 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: HOUR-NQTV (HOUR-NQTV). ID: 21 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. IMGN-NQTV | 2023-07-14 10:08:01.362 Mapping IMGN-NQTV to IMGN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: IMGN-NQTV (IMGN-NQTV). ID: 22 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: IMGN-NQTV (IMGN-NQTV). ID: 22 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SNTG-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AKAN-NQTV | 2023-07-14 10:08:01.362 Mapping AKAN-NQTV to AKAN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: AKAN-NQTV (AKAN-NQTV). ID: 23 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: AKAN-NQTV (AKAN-NQTV). ID: 23 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AKAN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SVRE-NQTV | 2023-07-14 10:08:01.362 Mapping SVRE-NQTV to SVRE-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: SVRE-NQTV (SVRE-NQTV). ID: 24 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: SVRE-NQTV (SVRE-NQTV). ID: 24 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SVRE-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. CVNA-NQTV | 2023-07-14 10:08:01.362 Mapping CVNA-NQTV to CVNA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: CVNA-NQTV (CVNA-NQTV). ID: 25 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: CVNA-NQTV (CVNA-NQTV). ID: 25 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. CVNA-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ENSC-NQTV | 2023-07-14 10:08:01.362 Mapping ENSC-NQTV to ENSC-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: ENSC-NQTV (ENSC-NQTV). ID: 26 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: ENSC-NQTV (ENSC-NQTV). ID: 26 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. TCRX-NQTV | 2023-07-14 10:08:01.362 Mapping TCRX-NQTV to TCRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: TCRX-NQTV (TCRX-NQTV). ID: 27 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: TCRX-NQTV (TCRX-NQTV). ID: 27 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ABNB-NQTV | 2023-07-14 10:08:01.362 Mapping ABNB-NQTV to ABNB-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: ABNB-NQTV (ABNB-NQTV). ID: 28 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: ABNB-NQTV (ABNB-NQTV). ID: 28 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SPRY-NQTV | 2023-07-14 10:08:01.362 Mapping SPRY-NQTV to SPRY-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: SPRY-NQTV (SPRY-NQTV). ID: 29 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: SPRY-NQTV (SPRY-NQTV). ID: 29 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. DRMA-NQTV | 2023-07-14 10:08:01.362 Mapping DRMA-NQTV to DRMA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: DRMA-NQTV (DRMA-NQTV). ID: 30 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: DRMA-NQTV (DRMA-NQTV). ID: 30 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. WISA-NQTV | 2023-07-14 10:08:01.362 Mapping WISA-NQTV to WISA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: WISA-NQTV (WISA-NQTV). ID: 31 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: WISA-NQTV (WISA-NQTV). ID: 31 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. MICS-NQTV | 2023-07-14 10:08:01.362 Mapping MICS-NQTV to MICS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: MICS-NQTV (MICS-NQTV). ID: 32 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: MICS-NQTV (MICS-NQTV). ID: 32 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. APLD-NQTV | 2023-07-14 10:08:01.362 Mapping APLD-NQTV to APLD-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: APLD-NQTV (APLD-NQTV). ID: 33 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: APLD-NQTV (APLD-NQTV). ID: 33 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. APLD-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SMFL-NQTV | 2023-07-14 10:08:01.362 Mapping SMFL-NQTV to SMFL-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: SMFL-NQTV (SMFL-NQTV). ID: 34 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: SMFL-NQTV (SMFL-NQTV). ID: 34 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SMFL-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. KBNT-NQTV | 2023-07-14 10:08:01.362 Mapping KBNT-NQTV to KBNT-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: KBNT-NQTV (KBNT-NQTV). ID: 35 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: KBNT-NQTV (KBNT-NQTV). ID: 35 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. IFBD-NQTV | 2023-07-14 10:08:01.362 Mapping IFBD-NQTV to IFBD-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: IFBD-NQTV (IFBD-NQTV). ID: 36 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: IFBD-NQTV (IFBD-NQTV). ID: 36 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. BMR | 2023-07-14 10:08:01.362 Mapping BMR to BMR. Service code: us_equities_utp_cta_exchange.data | 2023-07-14 10:08:01.362 SC DTC Delayed Exchange Data | Starting real-time market data updates for: BMR (BMR). ID: 37 Service code: us_equities_utp_cta_exchange.data | 2023-07-14 10:08:01.362 SC DTC Delayed Exchange Data | Connecting to the server ds3.sierracharts.com. Port 10043 | 2023-07-14 10:08:01.362 SC DTC Delayed Exchange Data | Requesting security definition data for: BMR (BMR). ID: 37 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SOUN-NQTV | 2023-07-14 10:08:01.362 Mapping SOUN-NQTV to SOUN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: SOUN-NQTV (SOUN-NQTV). ID: 38 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: SOUN-NQTV (SOUN-NQTV). ID: 38 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. SOUN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ELEV-NQTV | 2023-07-14 10:08:01.362 Mapping ELEV-NQTV to ELEV-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: ELEV-NQTV (ELEV-NQTV). ID: 39 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: ELEV-NQTV (ELEV-NQTV). ID: 39 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ONFO-NQTV | 2023-07-14 10:08:01.362 Mapping ONFO-NQTV to ONFO-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: ONFO-NQTV (ONFO-NQTV). ID: 40 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: ONFO-NQTV (ONFO-NQTV). ID: 40 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ELEV-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AAIC-NQTV | 2023-07-14 10:08:01.362 Mapping AAIC-NQTV to AAIC-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: AAIC-NQTV (AAIC-NQTV). ID: 41 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: AAIC-NQTV (AAIC-NQTV). ID: 41 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ETRN-NQTV | 2023-07-14 10:08:01.362 Mapping ETRN-NQTV to ETRN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: ETRN-NQTV (ETRN-NQTV). ID: 42 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: ETRN-NQTV (ETRN-NQTV). ID: 42 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. AMZN-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. JNJ-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. ABNB-NQTV | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. MRKR-NQTV | 2023-07-14 10:08:01.362 Mapping MRKR-NQTV to MRKR-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 DTC Client socket (3) | Creating socket. | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: MRKR-NQTV (MRKR-NQTV). ID: 43 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: MRKR-NQTV (MRKR-NQTV). ID: 43 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. UCAR-NQTV | 2023-07-14 10:08:01.362 Mapping UCAR-NQTV to UCAR-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 DTC Client socket (3) | New receive buffer size: 5242880 | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: UCAR-NQTV (UCAR-NQTV). ID: 44 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Requesting security definition data for: UCAR-NQTV (UCAR-NQTV). ID: 44 | 2023-07-14 10:08:01.362 Subscribing to symbol for symbol alert. REUN-NQTV | 2023-07-14 10:08:01.362 DTC Client socket (3) | Connecting to IP: 142.215.18.104. | 2023-07-14 10:08:01.362 Mapping REUN-NQTV to REUN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.362 Denali Data Feed | Starting real-time market data updates for: REUN-NQTV (REUN-NQTV). ID: 45 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: REUN-NQTV (REUN-NQTV). ID: 45 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. WLDS-NQTV | 2023-07-14 10:08:01.363 Mapping WLDS-NQTV to WLDS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: WLDS-NQTV (WLDS-NQTV). ID: 46 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: WLDS-NQTV (WLDS-NQTV). ID: 46 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. UCAR-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. WLDS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. UCAR-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. CNTB-NQTV | 2023-07-14 10:08:01.363 Mapping CNTB-NQTV to CNTB-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: CNTB-NQTV (CNTB-NQTV). ID: 47 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: CNTB-NQTV (CNTB-NQTV). ID: 47 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. DGLY-NQTV | 2023-07-14 10:08:01.363 Mapping DGLY-NQTV to DGLY-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: DGLY-NQTV (DGLY-NQTV). ID: 48 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: DGLY-NQTV (DGLY-NQTV). ID: 48 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. DGLY-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. CNTB-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. FRZA-NQTV | 2023-07-14 10:08:01.363 Mapping FRZA-NQTV to FRZA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: FRZA-NQTV (FRZA-NQTV). ID: 49 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: FRZA-NQTV (FRZA-NQTV). ID: 49 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. TMBR-NQTV | 2023-07-14 10:08:01.363 Mapping TMBR-NQTV to TMBR-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: TMBR-NQTV (TMBR-NQTV). ID: 50 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: TMBR-NQTV (TMBR-NQTV). ID: 50 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. CJET-NQTV | 2023-07-14 10:08:01.363 Mapping CJET-NQTV to CJET-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: CJET-NQTV (CJET-NQTV). ID: 51 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: CJET-NQTV (CJET-NQTV). ID: 51 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. EVAX-NQTV | 2023-07-14 10:08:01.363 Mapping EVAX-NQTV to EVAX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: EVAX-NQTV (EVAX-NQTV). ID: 52 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: EVAX-NQTV (EVAX-NQTV). ID: 52 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. HOTH-NQTV | 2023-07-14 10:08:01.363 Mapping HOTH-NQTV to HOTH-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: HOTH-NQTV (HOTH-NQTV). ID: 53 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: HOTH-NQTV (HOTH-NQTV). ID: 53 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. HOTH-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. CJET-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. FARM-NQTV | 2023-07-14 10:08:01.363 Mapping FARM-NQTV to FARM-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: FARM-NQTV (FARM-NQTV). ID: 54 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: FARM-NQTV (FARM-NQTV). ID: 54 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. FARM-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BAOS-NQTV | 2023-07-14 10:08:01.363 Mapping BAOS-NQTV to BAOS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: BAOS-NQTV (BAOS-NQTV). ID: 55 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: BAOS-NQTV (BAOS-NQTV). ID: 55 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. META-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. MGRX-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BAOS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. MGRX-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BAOS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SNOA-NQTV | 2023-07-14 10:08:01.363 Mapping SNOA-NQTV to SNOA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: SNOA-NQTV (SNOA-NQTV). ID: 56 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: SNOA-NQTV (SNOA-NQTV). ID: 56 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. CFRX-NQTV | 2023-07-14 10:08:01.363 Mapping CFRX-NQTV to CFRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: CFRX-NQTV (CFRX-NQTV). ID: 57 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: CFRX-NQTV (CFRX-NQTV). ID: 57 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SIEN-NQTV | 2023-07-14 10:08:01.363 Mapping SIEN-NQTV to SIEN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: SIEN-NQTV (SIEN-NQTV). ID: 58 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: SIEN-NQTV (SIEN-NQTV). ID: 58 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SIEN-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. ASST-NQTV | 2023-07-14 10:08:01.363 Mapping ASST-NQTV to ASST-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: ASST-NQTV (ASST-NQTV). ID: 59 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: ASST-NQTV (ASST-NQTV). ID: 59 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. IFBD-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. ASST-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SOFO-NQTV | 2023-07-14 10:08:01.363 Mapping SOFO-NQTV to SOFO-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: SOFO-NQTV (SOFO-NQTV). ID: 60 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: SOFO-NQTV (SOFO-NQTV). ID: 60 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. YS-NQTV | 2023-07-14 10:08:01.363 Mapping YS-NQTV to YS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: YS-NQTV (YS-NQTV). ID: 61 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: YS-NQTV (YS-NQTV). ID: 61 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. FWBI-NQTV | 2023-07-14 10:08:01.363 Mapping FWBI-NQTV to FWBI-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: FWBI-NQTV (FWBI-NQTV). ID: 62 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: FWBI-NQTV (FWBI-NQTV). ID: 62 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. IPX-NQTV | 2023-07-14 10:08:01.363 Mapping IPX-NQTV to IPX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: IPX-NQTV (IPX-NQTV). ID: 63 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: IPX-NQTV (IPX-NQTV). ID: 63 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SOFO-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. IPX-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BWV-NQTV | 2023-07-14 10:08:01.363 Mapping BWV-NQTV to BWV-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: BWV-NQTV (BWV-NQTV). ID: 64 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: BWV-NQTV (BWV-NQTV). ID: 64 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. WISA-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. NEXT-NQTV | 2023-07-14 10:08:01.363 Mapping NEXT-NQTV to NEXT-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: NEXT-NQTV (NEXT-NQTV). ID: 65 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: NEXT-NQTV (NEXT-NQTV). ID: 65 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. IVA-NQTV | 2023-07-14 10:08:01.363 Mapping IVA-NQTV to IVA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: IVA-NQTV (IVA-NQTV). ID: 66 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: IVA-NQTV (IVA-NQTV). ID: 66 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. WETG-NQTV | 2023-07-14 10:08:01.363 Mapping WETG-NQTV to WETG-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: WETG-NQTV (WETG-NQTV). ID: 67 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: WETG-NQTV (WETG-NQTV). ID: 67 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BWV-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. NEXT-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. WISA-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. NEXT-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. EDTX-NQTV | 2023-07-14 10:08:01.363 Mapping EDTX-NQTV to EDTX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: EDTX-NQTV (EDTX-NQTV). ID: 68 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: EDTX-NQTV (EDTX-NQTV). ID: 68 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SOFO-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. VCIG-NQTV | 2023-07-14 10:08:01.363 Mapping VCIG-NQTV to VCIG-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: VCIG-NQTV (VCIG-NQTV). ID: 69 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: VCIG-NQTV (VCIG-NQTV). ID: 69 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. NUWE-NQTV | 2023-07-14 10:08:01.363 Mapping NUWE-NQTV to NUWE-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: NUWE-NQTV (NUWE-NQTV). ID: 70 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: NUWE-NQTV (NUWE-NQTV). ID: 70 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BOF-NQTV | 2023-07-14 10:08:01.363 Mapping BOF-NQTV to BOF-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: BOF-NQTV (BOF-NQTV). ID: 71 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: BOF-NQTV (BOF-NQTV). ID: 71 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. BOF-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. VCIG-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. AHI-NQTV | 2023-07-14 10:08:01.363 Mapping AHI-NQTV to AHI-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: AHI-NQTV (AHI-NQTV). ID: 72 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: AHI-NQTV (AHI-NQTV). ID: 72 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. OCEA-NQTV | 2023-07-14 10:08:01.363 Mapping OCEA-NQTV to OCEA-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: OCEA-NQTV (OCEA-NQTV). ID: 73 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: OCEA-NQTV (OCEA-NQTV). ID: 73 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. OCEA-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. DIS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. LCFY-NQTV | 2023-07-14 10:08:01.363 Mapping LCFY-NQTV to LCFY-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: LCFY-NQTV (LCFY-NQTV). ID: 74 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: LCFY-NQTV (LCFY-NQTV). ID: 74 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. PIXY-NQTV | 2023-07-14 10:08:01.363 Mapping PIXY-NQTV to PIXY-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: PIXY-NQTV (PIXY-NQTV). ID: 75 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: PIXY-NQTV (PIXY-NQTV). ID: 75 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. ROOT-NQTV | 2023-07-14 10:08:01.363 Mapping ROOT-NQTV to ROOT-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: ROOT-NQTV (ROOT-NQTV). ID: 76 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: ROOT-NQTV (ROOT-NQTV). ID: 76 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. AMD-NQTV | 2023-07-14 10:08:01.363 Mapping AMD-NQTV to AMD-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: AMD-NQTV (AMD-NQTV). ID: 77 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: AMD-NQTV (AMD-NQTV). ID: 77 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. IWM-NQTV | 2023-07-14 10:08:01.363 Mapping IWM-NQTV to IWM-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: IWM-NQTV (IWM-NQTV). ID: 78 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: IWM-NQTV (IWM-NQTV). ID: 78 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. T-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. MEDS-NQTV | 2023-07-14 10:08:01.363 Mapping MEDS-NQTV to MEDS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: MEDS-NQTV (MEDS-NQTV). ID: 79 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: MEDS-NQTV (MEDS-NQTV). ID: 79 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. ROOT-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. MEDS-NQTV | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. FEMY-NQTV | 2023-07-14 10:08:01.363 Mapping FEMY-NQTV to FEMY-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: FEMY-NQTV (FEMY-NQTV). ID: 80 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: FEMY-NQTV (FEMY-NQTV). ID: 80 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. MLTX-NQTV | 2023-07-14 10:08:01.363 Mapping MLTX-NQTV to MLTX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: MLTX-NQTV (MLTX-NQTV). ID: 81 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: MLTX-NQTV (MLTX-NQTV). ID: 81 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. SHOP-NQTV | 2023-07-14 10:08:01.363 Mapping SHOP-NQTV to SHOP-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Starting real-time market data updates for: SHOP-NQTV (SHOP-NQTV). ID: 82 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.363 Denali Data Feed | Requesting security definition data for: SHOP-NQTV (SHOP-NQTV). ID: 82 | 2023-07-14 10:08:01.363 Subscribing to symbol for symbol alert. MEDS-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. BDTX-NQTV | 2023-07-14 10:08:01.364 Mapping BDTX-NQTV to BDTX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: BDTX-NQTV (BDTX-NQTV). ID: 83 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: BDTX-NQTV (BDTX-NQTV). ID: 83 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. CNTG-NQTV | 2023-07-14 10:08:01.364 Mapping CNTG-NQTV to CNTG-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: CNTG-NQTV (CNTG-NQTV). ID: 84 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: CNTG-NQTV (CNTG-NQTV). ID: 84 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. AREB-NQTV | 2023-07-14 10:08:01.364 Mapping AREB-NQTV to AREB-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: AREB-NQTV (AREB-NQTV). ID: 85 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: AREB-NQTV (AREB-NQTV). ID: 85 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. AREB-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. TOVX-NQTV | 2023-07-14 10:08:01.364 Mapping TOVX-NQTV to TOVX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: TOVX-NQTV (TOVX-NQTV). ID: 86 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: TOVX-NQTV (TOVX-NQTV). ID: 86 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. NERV-NQTV | 2023-07-14 10:08:01.364 Mapping NERV-NQTV to NERV-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: NERV-NQTV (NERV-NQTV). ID: 87 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: NERV-NQTV (NERV-NQTV). ID: 87 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. KLR-NQTV | 2023-07-14 10:08:01.364 Mapping KLR-NQTV to KLR-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: KLR-NQTV (KLR-NQTV). ID: 88 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: KLR-NQTV (KLR-NQTV). ID: 88 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. KLR-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. SHOP-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. PLM-NQTV | 2023-07-14 10:08:01.364 Mapping PLM-NQTV to PLM-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: PLM-NQTV (PLM-NQTV). ID: 89 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: PLM-NQTV (PLM-NQTV). ID: 89 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. AHI-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. IMPL | 2023-07-14 10:08:01.364 Mapping IMPL to IMPL. Service code: us_equities_utp_cta_exchange.data | 2023-07-14 10:08:01.364 SC DTC Delayed Exchange Data | Starting real-time market data updates for: IMPL (IMPL). ID: 90 Service code: us_equities_utp_cta_exchange.data | 2023-07-14 10:08:01.364 SC DTC Delayed Exchange Data | Requesting security definition data for: IMPL (IMPL). ID: 90 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. CRBU-NQTV | 2023-07-14 10:08:01.364 Mapping CRBU-NQTV to CRBU-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: CRBU-NQTV (CRBU-NQTV). ID: 91 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: CRBU-NQTV (CRBU-NQTV). ID: 91 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. CRBU-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. GRRR-NQTV | 2023-07-14 10:08:01.364 Mapping GRRR-NQTV to GRRR-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: GRRR-NQTV (GRRR-NQTV). ID: 92 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: GRRR-NQTV (GRRR-NQTV). ID: 92 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. CSTL-NQTV | 2023-07-14 10:08:01.364 Mapping CSTL-NQTV to CSTL-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: CSTL-NQTV (CSTL-NQTV). ID: 93 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: CSTL-NQTV (CSTL-NQTV). ID: 93 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. GRRR-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. SOS-NQTV | 2023-07-14 10:08:01.364 Mapping SOS-NQTV to SOS-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: SOS-NQTV (SOS-NQTV). ID: 94 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: SOS-NQTV (SOS-NQTV). ID: 94 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. ELOX-NQTV | 2023-07-14 10:08:01.364 Mapping ELOX-NQTV to ELOX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: ELOX-NQTV (ELOX-NQTV). ID: 95 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: ELOX-NQTV (ELOX-NQTV). ID: 95 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. SOS-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. ELOX-NQTV | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. GDTC-NQTV | 2023-07-14 10:08:01.364 Mapping GDTC-NQTV to GDTC-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: GDTC-NQTV (GDTC-NQTV). ID: 96 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: GDTC-NQTV (GDTC-NQTV). ID: 96 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. RXRX-NQTV | 2023-07-14 10:08:01.364 Mapping RXRX-NQTV to RXRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: RXRX-NQTV (RXRX-NQTV). ID: 97 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: RXRX-NQTV (RXRX-NQTV). ID: 97 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. HCTI-NQTV | 2023-07-14 10:08:01.364 Mapping HCTI-NQTV to HCTI-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: HCTI-NQTV (HCTI-NQTV). ID: 98 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: HCTI-NQTV (HCTI-NQTV). ID: 98 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. AULT-NQTV | 2023-07-14 10:08:01.364 Mapping AULT-NQTV to AULT-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: AULT-NQTV (AULT-NQTV). ID: 99 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: AULT-NQTV (AULT-NQTV). ID: 99 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. CVKD-NQTV | 2023-07-14 10:08:01.364 Mapping CVKD-NQTV to CVKD-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: CVKD-NQTV (CVKD-NQTV). ID: 100 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: CVKD-NQTV (CVKD-NQTV). ID: 100 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. AVRO-NQTV | 2023-07-14 10:08:01.364 Mapping AVRO-NQTV to AVRO-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: AVRO-NQTV (AVRO-NQTV). ID: 101 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: AVRO-NQTV (AVRO-NQTV). ID: 101 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. JZXN-NQTV | 2023-07-14 10:08:01.364 Mapping JZXN-NQTV to JZXN-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: JZXN-NQTV (JZXN-NQTV). ID: 102 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: JZXN-NQTV (JZXN-NQTV). ID: 102 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. SXTP-NQTV | 2023-07-14 10:08:01.364 Mapping SXTP-NQTV to SXTP-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: SXTP-NQTV (SXTP-NQTV). ID: 103 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: SXTP-NQTV (SXTP-NQTV). ID: 103 | 2023-07-14 10:08:01.364 Subscribing to symbol for symbol alert. SNAL-NQTV | 2023-07-14 10:08:01.364 Mapping SNAL-NQTV to SNAL-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Starting real-time market data updates for: SNAL-NQTV (SNAL-NQTV). ID: 104 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.364 Denali Data Feed | Requesting security definition data for: SNAL-NQTV (SNAL-NQTV). ID: 104 | 2023-07-14 10:08:01.364 Notice: Not connected to Live trading account to receive CME realtime futures data at non-professional fees. | 2023-07-14 10:08:01.364 No download requests in the queue to start downloads for. | 2023-07-14 10:08:01.364 SC DTC Delayed Exchange Data | Network connection to server complete. | 2023-07-14 10:08:01.369 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2023-07-14 10:08:01.369 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-14 10:08:01.369 SC DTC Delayed Exchange Data | Network connection to server complete. | 2023-07-14 10:08:01.370 SC DTC Delayed Exchange Data | Starting socket receive thread. | 2023-07-14 10:08:01.370 SC DTC Delayed Exchange Data | Sending encoding request to server: Binary VLS. Compression: standard | 2023-07-14 10:08:01.370 Denali Data Feed | Network connection to server complete. | 2023-07-14 10:08:01.397 Denali Data Feed | Starting socket receive thread. | 2023-07-14 10:08:01.397 Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: high | 2023-07-14 10:08:01.397 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2023-07-14 10:08:01.405 SC DTC Delayed Exchange Data | Sending logon request message. | 2023-07-14 10:08:01.405 SC DTC Delayed Exchange Data | Setting DTC encoding to Binary VLS | 2023-07-14 10:08:01.413 SC DTC Delayed Exchange Data | Sending logon request message. | 2023-07-14 10:08:01.413 Denali Data Feed | Setting DTC encoding to Binary VLS | 2023-07-14 10:08:01.450 Denali Data Feed | Sending logon request message. | 2023-07-14 10:08:01.450 Mapping PFRX-NQTV to PFRX-NQTV. Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.762 Denali Data Feed | Starting real-time market data updates for: PFRX-NQTV (PFRX-NQTV). ID: 105 Service code: nasdaq_exchange.data | 2023-07-14 10:08:01.762 Denali Data Feed | Requesting security definition data for: PFRX-NQTV (PFRX-NQTV). ID: 105 | 2023-07-14 10:08:01.762 Added historical Intraday data request for PFRX-NQTV to the queue. | 2023-07-14 10:08:01.762 Intraday data recording state for symbol PFRX-NQTV is set to download 'Pending'. | 2023-07-14 10:08:01.762 Triggering next historical data download in queue. | 2023-07-14 10:08:01.762 Delaying start of download for PFRX-NQTV. | 2023-07-14 10:08:01.762 SC DTC Delayed Exchange Data | Received logon response. | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Successfully connected. | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Trading is not supported. | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESH23-CME -> MESH23 | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: MESM23-CME -> MESM23 | 2023-07-14 10:08:02.033 SC DTC Delayed Exchange Data | Received logon response. | 2023-07-14 10:08:02.035 SC DTC Delayed Exchange Data | Server Name: SC Realtime Server. | 2023-07-14 10:08:02.035 SC DTC Delayed Exchange Data | Server protocol version: 8. Client protocol version: 8 | 2023-07-14 10:08:02.035 SC DTC Delayed Exchange Data | Successfully connected. | 2023-07-14 10:08:02.035 SC DTC Delayed Exchange Data | Trading is not supported. | 2023-07-14 10:08:02.035 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: BMR -> BMR | 2023-07-14 10:08:02.035 SC DTC Delayed Exchange Data | Restarting real-time data updates for symbol: IMPL -> IMPL | 2023-07-14 10:08:02.035 Denali Data Feed | Received logon response. | 2023-07-14 10:08:02.114 Denali Data Feed | Server Name: SC Realtime Server. | 2023-07-14 10:08:02.114 Denali Data Feed | Server protocol version: 8. Client protocol version: 8 | 2023-07-14 10:08:02.114 Denali Data Feed | Successfully connected. | 2023-07-14 10:08:02.114 Denali Data Feed | Trading is not supported. | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AAIC-NQTV -> AAIC-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ABNB-NQTV -> ABNB-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AHI-NQTV -> AHI-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AKAN-NQTV -> AKAN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AMD-NQTV -> AMD-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AMZN-NQTV -> AMZN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: APLD-NQTV -> APLD-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AREB-NQTV -> AREB-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ASST-NQTV -> ASST-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ATOM-NQTV -> ATOM-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AULT-NQTV -> AULT-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: AVRO-NQTV -> AVRO-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: BABA-NQTV -> BABA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: BAOS-NQTV -> BAOS-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: BDTX-NQTV -> BDTX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: BOF-NQTV -> BOF-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: BWV-NQTV -> BWV-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: BXRX-NQTV -> BXRX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CFRX-NQTV -> CFRX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CJET-NQTV -> CJET-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CNTB-NQTV -> CNTB-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CNTG-NQTV -> CNTG-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CRBU-NQTV -> CRBU-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CSTL-NQTV -> CSTL-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CVKD-NQTV -> CVKD-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: CVNA-NQTV -> CVNA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: DGLY-NQTV -> DGLY-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: DIS-NQTV -> DIS-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: DRMA-NQTV -> DRMA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: EDTX-NQTV -> EDTX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ELEV-NQTV -> ELEV-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ELOX-NQTV -> ELOX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ENSC-NQTV -> ENSC-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ETRN-NQTV -> ETRN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: EVAX-NQTV -> EVAX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: FARM-NQTV -> FARM-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: FEMY-NQTV -> FEMY-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: FRZA-NQTV -> FRZA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: FWBI-NQTV -> FWBI-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: GDTC-NQTV -> GDTC-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: GRRR-NQTV -> GRRR-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: GSUN-NQTV -> GSUN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: HCTI-NQTV -> HCTI-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: HOTH-NQTV -> HOTH-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: HOUR-NQTV -> HOUR-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: IFBD-NQTV -> IFBD-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: IMGN-NQTV -> IMGN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: INAB-NQTV -> INAB-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: IPX-NQTV -> IPX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: IVA-NQTV -> IVA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: IWM-NQTV -> IWM-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: JNJ-NQTV -> JNJ-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: JPM-NQTV -> JPM-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: JZXN-NQTV -> JZXN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: KBNT-NQTV -> KBNT-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: KLR-NQTV -> KLR-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: LCFY-NQTV -> LCFY-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: MEDS-NQTV -> MEDS-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: META-NQTV -> META-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: MGRX-NQTV -> MGRX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: MICS-NQTV -> MICS-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: MLTX-NQTV -> MLTX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: MRKR-NQTV -> MRKR-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: NERV-NQTV -> NERV-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: NEXT-NQTV -> NEXT-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: NKE-NQTV -> NKE-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: NUWE-NQTV -> NUWE-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: NVDA-NQTV -> NVDA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: OCEA-NQTV -> OCEA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ONFO-NQTV -> ONFO-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: PFRX-NQTV -> PFRX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: PIXY-NQTV -> PIXY-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: PLM-NQTV -> PLM-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: REUN-NQTV -> REUN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: ROOT-NQTV -> ROOT-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: RXRX-NQTV -> RXRX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SHOP-NQTV -> SHOP-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SIEN-NQTV -> SIEN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SMFL-NQTV -> SMFL-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SNAL-NQTV -> SNAL-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SNOA-NQTV -> SNOA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SNTG-NQTV -> SNTG-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SOFO-NQTV -> SOFO-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SOS-NQTV -> SOS-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SOUN-NQTV -> SOUN-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SPRY-NQTV -> SPRY-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SPY-NQTV -> SPY-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SVRE-NQTV -> SVRE-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: SXTP-NQTV -> SXTP-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: T-NQTV -> T-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: TCRX-NQTV -> TCRX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: TMBR-NQTV -> TMBR-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: TOVX-NQTV -> TOVX-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: TSLA-NQTV -> TSLA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: UCAR-NQTV -> UCAR-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: VCIG-NQTV -> VCIG-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: WETG-NQTV -> WETG-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: WISA-NQTV -> WISA-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: WLDS-NQTV -> WLDS-NQTV | 2023-07-14 10:08:02.114 Denali Data Feed | Restarting real-time data updates for symbol: YS-NQTV -> YS-NQTV | 2023-07-14 10:08:02.114 SC DTC Delayed Exchange Data | Real-time data for symbol MESH23-CME is currently unavailable. | 2023-07-14 10:08:02.128 SC DTC Delayed Exchange Data | Received security definition for symbol MESH23-CME | 2023-07-14 10:08:02.128 SC DTC Delayed Exchange Data | Real-time data for symbol MESM23-CME is currently unavailable. | 2023-07-14 10:08:02.128 SC DTC Delayed Exchange Data | Received security definition for symbol MESM23-CME | 2023-07-14 10:08:02.128 SC DTC Delayed Exchange Data | Received security definition for symbol BMR | 2023-07-14 10:08:02.129 SC DTC Delayed Exchange Data | Received security definition for symbol IMPL | 2023-07-14 10:08:02.129 HD Request # 10 | Downloading Intraday chart data for PFRX-NQTV to the file PFRX-NQTV.scid. Service: nasdaq_exchange.data | 2023-07-14 10:08:18.462 HD Request # 10 | Download start date-time: 2023-07-04 10:08:18.000000. File last date-time: 00:00:00.000000 | 2023-07-14 10:08:18.462 HD Request # 10 | Using server: ds25.sierracharts.com port 10149 | 2023-07-14 10:08:18.462 Socket (4) | Creating socket. | 2023-07-14 10:08:18.462 Socket (4) | New receive buffer size: 5242880 | 2023-07-14 10:08:18.462 Socket (4) | Connecting to IP: 38.65.8.115. | 2023-07-14 10:08:18.462 HD Request # 10 | Setting DTC encoding to Binary VLS | 2023-07-14 10:08:18.532 HD Request # 10 | Sending historical data logon request message. | 2023-07-14 10:08:18.532 HD Request # 10 | Requesting Intraday data. Start date-time: 2023-07-04 10:08:18. Record interval: 0. Symbol: PFRX-NQTV | 2023-07-14 10:08:19.007 Socket (4) | CloseSocket call. | 2023-07-14 10:08:19.041 HD Request # 10 | Error downloading historical Intraday data for PFRX-NQTV. Historical data file not available for symbol. | 2023-07-14 10:08:19.041 Socket (4) | Shutdown started. Waiting for graceful close. | 2023-07-14 10:08:19.041 Historical data download thread signaled to stop. | 2023-07-14 10:08:19.041 HD Request # 10 | Received 0 Intraday data records from 00:00:00.000000 to 00:00:00.000000 (0.0 seconds and wrote 0 records for PFRX-NQTV | 2023-07-14 10:08:19.041 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 00:00:00.000000 | 2023-07-14 10:08:19.042 HD Request # 10 | Completion time: 1s. | 2023-07-14 10:08:19.042 HD Request # 10 | Intraday data download complete for PFRX-NQTV. Unique request ID: 5 | 2023-07-14 10:08:19.042 Removing historical data download ID 5. | 2023-07-14 10:08:19.042 Real-time Intraday chart data file updates started for PFRX-NQTV | 2023-07-14 10:08:19.042 Intraday chart data file opened for PFRX-NQTV | 2023-07-14 10:08:19.042 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2023-07-14 10:08:19.042 Triggering next historical data download in queue. | 2023-07-14 10:08:19.042 No download requests in the queue to start downloads for. | 2023-07-14 10:08:19.042 Socket (4) | Socket gracefully closed by remote side. | 2023-07-14 10:08:19.074 Socket (4) | Closed. | 2023-07-14 10:08:19.074 |
[2023-07-14 15:11:41] |
John - SC Support - Posts: 36344 |
If you are having an issue with just the symbol PFRX-NQTV, then this is because this is not a valid stock. Did you intend to type in PRFX-NQTV, for which there is a stock (PainReform Ltd.)?
[2023-07-14 15:22:00] |
Shawn J - Posts: 32 |
My apologies. I did intend to type PRFX-NQTV instead of PFRX-NQTV. As I'm going through stocks, all my data is now appearing. So it seems like everything is working now.
