Date/Time: Fri, 22 Nov 2024 08:20:20 +0000
Number Bar Data for 2 days Back only With Zen Fire Data
View Count: 1908
[2013-05-02 20:15:54] |
Moti - Posts: 63 |
I subscribe to Sierra 15 Day Free trail,& Using Mirus Zen fire data. I get Only 2 days of data Number Bar Study. Any idea How to get More Days ? Thank you, Moti |
[2013-05-02 23:08:02] |
Yes this is true because Zen-Fire does not have historical Bid Volume or Ask Volume. Please see: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ServicesThatSupportBVandAV Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-02 23:08:31
[2013-05-03 10:12:27] |
Moti - Posts: 63 |
If I will sescribe to Sierra: I Will Have Historical Bid /Ask volume Via Sierra historical data ? If Yes Can i Mix historical and online Zen fire in the same chart? If Not What is the best solution to Have this Historical Future data Thank you Moti |
[2013-05-03 13:20:44] |
The historical data Sierra Chart provides, cannot be directly used with Zen-Fire. The solution is to use one of the supported Data or Trading services here: http://www.sierrachart.com/index.php?l=doc/doc_NumbersBars.php#ServicesThatSupportBVandAV Or maintain a connection to the Zen-Fire service as much as possible so you do not miss any real-time data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-05-03 13:22:27
