Date/Time: Wed, 27 Nov 2024 19:43:37 +0000
average volume of the night
View Count: 265
[2023-07-14 10:51:36] |
User285770 - Posts: 41 |
Hello, where do I check the average volume of the night?
[2023-07-14 14:13:07] |
John - SC Support - Posts: 36344 |
It depends on what exactly you want to see in terms of "Average". To begin with, you would need to open a chart with just the overnight session defined. Refer to the following: Chart Session Times Then depending on what you want to see, you could add the Volume Study with a Moving Average. Refer to the following: Volume Moving Average - Simple For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
