Date/Time: Wed, 27 Nov 2024 19:28:55 +0000
REQUEST TO CHANGE SERVICE PACKAGE
View Count: 238
[2023-07-14 08:31:47] |
User161986 - Posts: 2 |
HELLO THERE AM NTALE RAY I SELECTED THE INTEGRATED STANDARD SERVICE PACKAGE 10 BUT I WANTED THE BASE SEIRRA CHART WITH ADVANCED FEATURES SERVICE PACKAGE 5 CAN YOU DOWNGRADE ME TO IT ? |
[2023-07-14 13:58:51] |
John - SC Support - Posts: 36341 |
We see you are on Package 5 at this time. Just so you are aware, you can change your package at any time by selecting the package you want on the Activate Services page and selecting the "Update/Set" button. When you do this, the remaining Usage Time is adjusted based on the difference in price of the packages. If you change to a more expensive package, your remaining Usage Time will go down and vice versa. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
