Date/Time: Wed, 27 Nov 2024 18:34:55 +0000
Plus Cursor Color change
View Count: 338
[2023-07-13 15:59:40] |
MattH - Posts: 27 |
I have two separate installations of sierra chart. Both use dark backgrounds for charts. In the first installation the cursor is always white so I can always see it whether it's a +, pointer or hand. In the second installation when crosshair is selected I can see the white cross hair. However when I left click the mouse to disable the crosshair and only see the + cursor it changes color. It becomes black and I can no longer see it on the dark background. If I select hand or pointer it is always white, it only occurs with the + sign of the crosshair. I didn't change anything when I installed the second installation so not sure why this is happening.
[2023-07-13 16:38:08] |
John - SC Support - Posts: 36331 |
The control over the color of the cursor is done through the Operating System. We have no idea how it would be one way in one instance and another way in another instance. But there is an option for "Inverted" for the color at least within Windows 11. Check how you have the cursor color set in the Windows Settings.
