Date/Time: Wed, 27 Nov 2024 18:31:55 +0000
Tiling Windows As Grid
View Count: 557
[2023-07-13 10:47:21] |
user8888 - Posts: 159 |
Hello, In the case that I'd like to tile 8 charts in a screen, is it possible to tile them in a standard 4x4 configuration? because, with the tiling options in the window menu, it is tiling them in a certain cool but exotic way What about a simple 4 x 4 ? Thank you |
grid-1.png / V - Attached On 2023-07-13 10:38:47 UTC - Size: 413.52 KB - 123 views grid-2.png / V - Attached On 2023-07-13 10:38:51 UTC - Size: 380.23 KB - 104 views |
[2023-07-13 15:06:42] |
John - SC Support - Posts: 36331 |
Refer to the "Tile as Grid" options starting here, to see if this will do what you want: Window, CB and CW Menus: Tile as Grid - Horizontally (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-13 16:04:44] |
the attached 2 pics are from both "Tile As Grid - Horizontally" & "Tile As Grid - Vertically" it doesn't do 4 - 4 but 3 - 3 - 2 |
[2023-07-13 16:06:52] |
Sierra_Chart Engineering - Posts: 17198 |
You can control this: General Settings Window: Use Windows Custom Grid Layout (Global Settings >> General Settings >> Windows >> Window Tiling) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-13 16:06:58
[2023-07-13 16:19:45] |
ok, I didn't know that. setting it at 2 rows and 4 columns, works as expected (4-4) Thank you! |
