Date/Time: Wed, 27 Nov 2024 18:39:41 +0000
Is it possible to link 2 broker accounts to one sierra charts account?
View Count: 268
[2023-07-13 08:25:08]
User783378 - Posts: 1
Hello, I would like to trade 2 assets but separetely. Is it possible and if yes then can you advise?
Regards
Peter
[2023-07-13 15:00:00]
John - SC Support - Posts: 36331
If we are understanding what you want, you would just need to install a second Sierra Chart on the same computer. Then you connect one installation to one of your brokerage accounts and the other to your other account. These would be completely separate controls for each account. There are no additional fees or anything special you have to do in this setup. Refer to the instructions here:
Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart
