Date/Time: Wed, 27 Nov 2024 17:52:16 +0000
Chart shows prices in hundredths rather than quarters
View Count: 349
[2023-07-13 00:55:00] |
User789676 - Posts: 6 |
ES chart somehow switched to showing price levels at 4508.01, 4507.71, 4507.38, 4507.08, etc, rather than .00, .25, .75. How do I get it back to show prices with the proper tick sizes?
Date Time Of Last Edit: 2023-07-15 00:58:29
decimals.PNG / V - Attached On 2023-07-13 00:48:30 UTC - Size: 228.81 KB - 82 views |
[2023-07-15 00:59:35] |
Can someone please help me with this??
[2023-07-15 01:38:12] |
user_xyz - Posts: 416 |
Check the following Chart Settings > Symbol ---Price Display Format (List) 0.01 ---Tick Size 0.2500 Date Time Of Last Edit: 2023-07-15 01:38:28
[2023-07-15 16:28:41] |
I had already checked that. My chart symbol settings are exactly as you recommend, but it still does not show correctly, as you can seen in this screenshot: https://www.sierrachart.com/image.php?Image=1689438412264.png
[2023-07-17 17:41:44] |
John - SC Support - Posts: 36329 |
Check the following setting: Chart Scale and Scale Adjusting: Scale Increment (Scale Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
