Date/Time: Wed, 27 Nov 2024 18:34:31 +0000
Average Continuous reset points
View Count: 254
[2023-07-12 20:46:35]
User265682 - Posts: 16
Is it possible to configure a 'session start' reset point for the Average Continuous study?
Currently the only option is start of the day - session start would be a great addition?
Thanks.
[2023-07-12 20:52:36]
John - SC Support - Posts: 36331
This is not something we have time to do. The source code for this study is available in the Studies8.cpp file in the ACS_Source folder under your main Sierra Chart installation. You can always modify it to your needs. Refer to the following:
How to Build an Advanced Custom Study from Source Code
[2023-07-13 06:54:04]
Great, thanks for confirming!
Will take a look.
