Date/Time: Wed, 27 Nov 2024 18:42:40 +0000
probleme de prix du tick
View Count: 305
[2023-07-12 19:06:58] |
User338651 - Posts: 14 |
re bonjour meme en telechargeant la derniere version (qui etait dejas en place) j'ai meme essayer la version precedente suite au message que vous m'avez envoyez , juste une amelioraton , le prix du tick est correct, j'execute un trade ok , il va dans mon sens , je suis en gain 3, voir 4 ticks de plus ,en cloturant l'ordre ,il me met en negatif 20x de plus , c'est affolant, les tests sont en train de me faire perdre merci d'avance de continuer a m'aider , depuis vendredi dernier, je ferme tout pour aujourdhui a demain cordialement |
[2023-07-12 19:50:46] |
John - SC Support - Posts: 36331 |
From Google Translate: even by downloading the latest version (which was already in place) I even tried the previous version following the message you sent me, just an improvement, the price of the tick is correct, I execute a trade ok, it going in my direction, I'm in gain 3, see 4 more ticks, by closing the order, it puts me in negative 20x more, it's maddening, the tests are making me lose
thank you in advance for continuing to help me, since last Friday, I close everything for today see you tomorrow The problem is that you are not getting the Real-Time data. Right now, you are getting delayed data, so what you are seeing for the data is not what is occurring in the market at that time. In order to get the real-time data for the CME Group, you need to go through the instructions at the following link: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
