Date/Time: Wed, 27 Nov 2024 18:42:44 +0000
Enable multiple connections
View Count: 270
[2023-07-12 13:48:36] |
User395567 - Posts: 5 |
Hello I’d like to enable multiple connections please. I use Sierra chart to execute my trades but I’m also connected with my CQG account to book maps platform which id like to use for the heat map and DOM Pro The issue I’m having is when I log into Sierra chart I get logged out of bookmap. Thanks! |
[2023-07-12 15:35:37] |
John - SC Support - Posts: 36331 |
We cannot help with this. Other than to recommend you leave CQG and use Teton order routing: Sierra Chart Teton Futures Order Routing You can do what you want with Teton order routing. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
