Date/Time: Wed, 27 Nov 2024 18:31:09 +0000
Renko Tick Size on Symbol Change
View Count: 302
[2023-07-12 03:40:59]
user_xyz - Posts: 416
Is there any way to have a single Renko chart and via symbol change save/remember the tick size for a specific symbol?
Flex Renko Example
NG 8-1-1
CL 6-1-1
NQ 25-2-1
I really want to have a single chart, setup Renko Brick sizing attached to a specific symbol, then without having to go into settings or use the Keyboard Hotkeys type in the 25-2-1fr every time I change the symbol from NQ (25-2-1) to CL (6-1-1) to NG (8-1-1)
Date Time Of Last Edit: 2023-07-13 23:27:12
[2023-07-13 23:26:01]
Any thoughts here can this be done?
[2023-07-14 13:49:05]
John - SC Support - Posts: 36331
This is not supported.
You could create a custom study that would do this by checking the symbol and then adjusting your settings as you want. Refer to the information starting here:
Advanced Custom Study Interface and Language (ACSIL): Introduction
