Date/Time: Thu, 10 Sep 2026 00:45:09 +0000
Trade window centering & marking a big buyer on the Numbers Bars?
View Count: 2364
[2014-07-05 21:37:50]
User93103 - Posts: 48
Hello:
Q1? In order to set the Bid/Ask volume at the trading price one has two options. One option is to double click on the price column and the next is to set it to automatic centering. Could you make a third option that is to add a bottom to the trade window so the Bid/Ask volume at the trading price can be center by clicking that bottom?
Q2)? How can we identify a big buyer/seller that traded at a price on the Numbers Bars? For example, a buyer just purchased 15 contracts of NQ at previous price of 3912?
God Bless
Ben
[2014-07-07 17:19:19]
1. You can set up a shortcut key for centering. The command is Trade >> Reset Trade DOM Scales. A keyboard shortcut can be set up for this. Here is the documentation for that :
Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu)
2. You can do this through the Time and Sales window:
http://www.sierrachart.com/index.php?l=doc/doc_TimeandSalesWindow.html
It is possible to do highlighting of trades based on comparison to a particular volume value.
[2014-07-10 12:21:09]
Hello:
The highlighting of trades based on comparison to a particular volume value is very helpful. What I am asking, is it possible to have a Numbers Bars charts that all of its entries are zero except when a buyer/seller with the contract size bigger than a set threshold trades. For example at a price 3850 of NQ, only show a trader's Bid/Ask size of bigger than 10 that is traded, and leave other entries as ZERO.
Also, the vertical centering data on the DOM can be established by modifying (adding a bottom) the Trade Window which is much easier for the traders like me than going through keyboard shortcut.
God Bless
Ben
[2014-07-10 16:44:16]
Therefore, sounds like you would want to use the Volume Filter setting:
Numbers Bars: Volume Filtering
[2014-07-11 17:42:04]
Hello:
Thank you, I got it.
Is there any example or explanation for the volume filtration (Volume Filter, Exclude <= 8) In your website other than the one you have guided me so Far.
God Bless
Ben
