Date/Time: Wed, 27 Nov 2024 18:42:53 +0000
Sierra Chart Logs
View Count: 219
[2023-07-11 08:16:28] |
User986567 - Posts: 18 |
Hello! Where can I find the software logs of software crashes etc. in sierra chart a few days ago? thank you. |
[2023-07-11 08:57:27] |
Sierra_Chart Engineering - Posts: 17198 |
It depends whether you have set Sierra Chart to save the log files. Refer to: Message Log: Automatically Saving Message Log to File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
