Date/Time: Wed, 27 Nov 2024 18:36:31 +0000
[User Discussion] - THE CHARTBOOK IS NOT COMPARTIBLE
View Count: 306
[2023-07-10 21:42:09] |
User712956 - Posts: 1 |
The Chart book am trying to load on my Chart was made on Sierra Chart 2065 which is an older version yet am using a the latest version of Sierra Chart 2517 hence failing to load, I'd be glad if you converted it to work on this latest version, thanks I've attached it below on the file. |
Private File |
[2023-07-11 13:25:23] |
John - SC Support - Posts: 36331 |
Follow the instructions at the following link to update the chartbook: Chartbooks (Workspaces): Opening Older Chartbooks Or you can go to G7FX to get an updated version. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
