Date/Time: Wed, 27 Nov 2024 18:38:41 +0000
Tade Log Statistic Expectancy
View Count: 278
[2023-07-10 20:57:56] |
User290484 - Posts: 19 |
Hi, Can you please tell me what the Expectancy value in the Tarde Log folder represents? Is it Ticks, points or perhaps $? If not Ticks, how can I change it to Ticks? Thank you |
[2023-07-11 02:43:43] |
Sierra_Chart Engineering - Posts: 17198 |
It is documented here: Trade Activity Log: Trade Statistics Fields Descriptions You cannot change the calculation of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
