Date/Time: Wed, 27 Nov 2024 18:48:56 +0000
[Locked] - Data issues
View Count: 342
[2023-07-10 18:19:38] |
User2007 - Posts: 5 |
hello Sir/ Madam I have purchaed pkg 11 and CME data but I have the issue getting very less order or volume in nasdaq future (NQ) which I think is not write in nasdaq type of market so kindly help with me issues thank you |
Screenshot 2023-07-10 at 11.09.22 PM.png / V - Attached On 2023-07-10 18:19:16 UTC - Size: 1.02 MB - 90 views |
[2023-07-10 21:28:48] |
John - SC Support - Posts: 36333 |
If you are referring to the Bids and Asks, then those match to what we see and expect for this product. If this is about the other numbers in your DOM, then we would need to know what columns those are and what time zone the DOM is set to (we see a time of 15:00:04 in the top). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-11 03:39:52] |
Blue column is bid and red one is asks and i using 9:30 new York time session Time zone :- New York time I think something is wrong about my data which I m receiving from sierra charts Broker name :- amp Service :- teton routing service Kindly help me with me problem |
[2023-07-11 03:42:33] |
In my footprint it's also showing same low order just like my Dom I'm using renko in it I purchased cme with non professional data -11$ |
[2023-07-11 13:43:24] |
There is nothing wrong with the data. What you are seeing is the correct data from the exchange. The total daily volume for NQ runs about 600000. The Micro NQ (MNQ) has a bit more volume running about 1000000 per day. You may want to look at this product instead. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-11 19:25:26] |
If you are saying the NQ has 600000 volume then why i m not able to see huge order in my dom In my dom there is very few order like a less volume market On the other hand when I open E mini s&p future I getting very nice volume . why I m not receive order just like e mini s&p like order Nasdaq and S&P both are stock market of us so there order most likely to be similar Help me |
[2023-07-11 21:40:27] |
Sierra_Chart Engineering - Posts: 17198 |
This is not within the scope of our support . You need to contact the exchange .
