Date/Time: Wed, 27 Nov 2024 17:54:15 +0000
Executing external programs on various events
View Count: 544
[2023-07-10 17:21:11]
User166108 - Posts: 73
Hi support,
Is there any way to execute external programs when an order gets filled or the position is otherwise updated?
I think the answer is "no, write your own plugin" which is fine but I just want to make sure of that.
If the answer is "no", is there a list of events anywhere or do we need to infer changes by maintaining last position size?
Thanks.
[2023-07-10 21:07:41]
John - SC Support - Posts: 36329
Yes you can through the Alerts functionality:
General Settings Window: Run Program When This Alert Triggered (Global Settings >> General Settings >> Alerts >> Alert Settings)
You can set a specific alert, for an order fill. Refer to the following:
Global Trade Settings Windows: Play Alert When Order Filled (Global Settings >> General Trade Settings >> Notifications)
[2023-07-10 22:58:02]
That looks close to what I need, but does the alert pass any parameters? I want to do something different when position=0 vs position!=0
[2023-07-11 13:32:03]
The alert does not pass any parameters. You would have to have two different alerts each calling different programs to do what you want.
[2023-07-11 14:04:15]
JohnR - User831573 - Posts: 306
Hope you don't mind my tagging on to this thread. I too have been contemplating how to connect SC to another program within the MSFT structure. Before retiring, I was around a lot of 'infrastructure' DB, MSG, WebApp. So I get the functionality of it. So, for my small project, would it be better to use the Event structure of C# & C++ as the method to connect or would a Messaging technology be better, have less issues? I might be partial, but seems like the ability to have the programs execute async of each other could be a good thing.
Maybe it would be simpler to implement since I don't have to worry C# / C++ exchanges. Just initialize & or connect to a queue and then put / get messages.
Pointers to places to get smarter or replies here would be greatly appreciated.
Retired (Old) self taught C++/C# -- past structured coder
JohnR
[2023-07-12 20:12:52]
JohnR, I wrote this to solve my problem, maybe you can use it as a starting point.
I also have a trade copier that I built.
#include "boost/format.hpp"
#include "boost/lexical_cast.hpp"
#include "boost/process.hpp"
#include "boost/process/windows.hpp"
#include "sierrachart.h"
#include <limits>
namespace bp = boost::process;
SCDLLName("Chart events plugin");
class ChartEvents
private:
double m_lastPosition = 0;
static void executeProgram(SCStudyInterfaceRef sc, std::string command,
std::vector<std::string> args)
SCString logMessage;
logMessage.Append("Executing command: ");
logMessage.Append(command.c_str());
logMessage.Append(" ");
for (auto const &arg : args)
logMessage.Append(arg.c_str());
sc.AddMessageToLog(logMessage, 0);
boost::process::spawn(command, boost::process::args(args),
bp::std_out > "output.log", bp::std_err > "error.log",
boost::process::windows::hide);
public:
void processPosition(SCStudyInterfaceRef sc, std::string const &pythonPath,
std::string const &onPositionChanged,
double currentPosition)
if (m_lastPosition == currentPosition)
return;
m_lastPosition = currentPosition;
if (onPositionChanged == "Unset" || onPositionChanged.empty())
return;
executeProgram(sc, pythonPath,
{onPositionChanged, sc.Symbol.GetChars(),
boost::lexical_cast<std::string>(currentPosition)});
SCSFExport scsf_ChartEvents(SCStudyInterfaceRef sc)
SCInputRef Input_PythonPath = sc.Input[0];
SCInputRef Input_OnPositionChange = sc.Input[1];
try
if (sc.SetDefaults)
sc.GraphName = "Chart events";
sc.StudyDescription = "Execute programs on chart events";
sc.GraphRegion = 0;
sc.FreeDLL = 1;
sc.AutoLoop = 0;
Input_PythonPath.Name = "Path to Python executable";
Input_PythonPath.SetString("");
Input_OnPositionChange.Name = "onPositionChangeCommand";
Input_OnPositionChange.SetDescription(
"Execute on position change: <your input> <current position>");
Input_OnPositionChange.SetString("");
else
auto ptr = (ChartEvents *)sc.GetPersistentPointer(1);
if (!ptr)
delete ptr;
ptr = new ChartEvents();
sc.SetPersistentPointer(1, ptr);
s_SCPositionData position;
sc.GetTradePosition(position);
ptr->processPosition(sc, Input_PythonPath.GetString(),
Input_OnPositionChange.GetString(),
position.PositionQuantity);
if (sc.LastCallToFunction)
delete ptr;
sc.SetPersistentPointer(1, nullptr);
catch (std::exception const &e)
sc.AddMessageToLog(e.what(), 1);
[2023-07-14 09:53:55]
Sierra_Chart Engineering - Posts: 17197
Parameters are passed when running a program when an alert is triggered:
[2023-07-16 19:47:01]
Ah too late, my plugin works sufficiently for me. Plus, I'm not sure of the format of various messages from your link above, is that listed somewhere? I might end up switching to it later when I need more events.
