Date/Time: Wed, 27 Nov 2024 18:28:40 +0000
Scale from 0 for indicator
View Count: 296
[2023-07-10 15:14:01] |
User361939 - Posts: 165 |
Hello, Please help me set correct scale for my indicator. (At the attachment screen) As you can see indicator has some values under 0 , but i don't need to see them, so i want to set 0 value almost on"time scale". I can make it manually but each time there is big value, it will move whole scale up/down. If i locked scale it does the same. How can i set scale for indicator so it I will see always value starting from 0, but if value is bigger than all seen on chart, it will scale whole view to this higher number but always starts from 0. Regards |
gc_scale.png / V - Attached On 2023-07-10 15:06:42 UTC - Size: 10.32 KB - 77 views |
[2023-07-10 16:54:03] |
John - SC Support - Posts: 36331 |
Set the scale for that study to "Automatic Zero Based". Refer to the following: Chart Scale and Scale Adjusting: Automatic Zero-Based (Scale Range) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-10 17:00:08] |
I did try that but than it doesn't feet corectly.(screen at the attachemnt) Screens are from the same chart. How can i set it properly? Date Time Of Last Edit: 2023-07-10 17:01:09
scale1_manually.png / V - Attached On 2023-07-10 16:59:56 UTC - Size: 19.78 KB - 74 views scale_based0.png / V - Attached On 2023-07-10 17:00:03 UTC - Size: 62.88 KB - 69 views |
[2023-07-10 17:13:44] |
We are not understanding the issue you are having. If this is about the fact that the '0' is not displayed on the side, then that is just a display item. The data is shown from 0 and up. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-10 17:21:52] |
Screen "manually" showing value for the highest bar- it is around 700 ( max on scale can be displayed value 1200) If you look on screen scale_0_based, bars has been cutted you don't see top of bar cuz their value is bigger than value 500 (that from some reason scale set to be displayed.) |
[2023-07-10 21:08:58] |
That should definitely not occur. Can you please give us the Chart that shows this issue by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
