Date/Time: Wed, 27 Nov 2024 18:36:27 +0000
Real time data
View Count: 296
[2023-07-10 14:22:04] |
User764155 - Posts: 10 |
I paid 56 $ for service 12, but I don't receive any real time data. Can you help me? Regards Contestabile Alfonso |
[2023-07-10 15:57:38] |
John - SC Support - Posts: 36331 |
What are the exchanges for which you want real-time data?
[2023-07-10 16:35:51] |
emini s&p 500 ( Cme)
[2023-07-10 17:08:24] |
The first thing is that you need to understand the CME Group requirement that in order to get the data at the "non-professional" rate, you need to have a live, funded, futures trading account. Refer to the following: Real-Time Exchange Data Feeds Available From Sierra Chart: Understanding and Accessing Data From the CME, CBOT, NYMEX, COMEX Exchanges If you do not have an account that qualifies for the above, then we recommend the solution outlined at the following link: Easy Solution to CME Funded Trading Account Requirement Once you have the above worked out, then you need to follow the instructions at the following link to get the data setup and functioning: Denali Exchange Data Feed: *Setup Instructions: CME/CBOT/NYMEX/COMEX Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
