Date/Time: Wed, 27 Nov 2024 18:34:50 +0000
automatic copy of drawings/tools
View Count: 223
[2023-07-10 13:22:32] |
Chris_Janowski - Posts: 5 |
Hello, I use 6 Oil CL charts with different bar times (M1, M4, M15, H1, H4, D1). I use "Extending Rectangle" tool often. When I draw it on my (for example) M4 chart, is it possible to get it automaticaly shown on other charts (M1, M15, H1, H4, D1) ? Without drawing it on other CL charts separately? with best regards, Chris |
[2023-07-10 13:56:08] |
User688525 - Posts: 259 |
Hi, On the M1, M15, H1, H4 and D1 charts that you want the drawings to appear on, go to "Chart Settings > Chart Drawings > Copy Chart Drawings From Chart #'s" and enter the M4 Chart #. |
[2023-07-10 15:56:39] |
John - SC Support - Posts: 36331 |
Refer to the following documentation: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
