Date/Time: Wed, 27 Nov 2024 18:29:47 +0000
How to color a bar if it's size (H-L) is bigger than any of the previous 5 bars?
View Count: 223
[2023-07-10 04:15:30] |
shire - Posts: 6 |
Currently using the "Color Bar based on Alert Condition" study and I'm not sure what formula to use to get it to color a bar a different color if it has a greater height than any of the previous 5 bars on a 2000 tick chart.
[2023-07-10 14:42:34] |
John - SC Support - Posts: 36331 |
It would be the following formula to test against the previous two bars (we leave it to you to expand it to 5 bars, or however many you want): = AND((H - L) > (H[-1] - L[-1]), (H - L) > (H[-2] - L[-2])) The particular items you need to reference are the following: Study/Chart Alerts And Scanning: OR and AND Functions Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables Study/Chart Alerts And Scanning: Referencing Data Other Than on the Last Bar/Column In the Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
