Date/Time: Wed, 27 Nov 2024 18:43:40 +0000
[User Discussion] - Min/Max delta
View Count: 801
[2023-07-10 04:01:11] |
Peeter Jakobson - Posts: 7 |
For my numbers bar chart, I would like to see Delta, Max Delta, Min Delta, Cumulative Delta and Total Volume at the bottom of the chart. I have been able to find videos on how to create the matrix at the bottom of the chart for Delta, Cumulative Delta and Total Volume. I have not been able to find how to add the Max and Min delta's. These two extra values would allow me to know how strong aggressive Buying was at one point in the bar (Max Delta) as well as, how strong aggressive Selling was at one point in the bar (Min Delta). What is that called by Sierra charts and how can I get it into my charts? Thank you |
[2023-07-10 14:39:10] |
John - SC Support - Posts: 36331 |
There are the following subgraphs in the Numbers Bars Calculated Values Study: - Maximum Ask Volume Bid Volume Difference - Minimum Ask Volume Bid Volume Difference Refer to the information here: Numbers Bars: Numbers Bars Calculated Values Subgraph Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-11 14:52:48] |
Instead of the difference between buyers and sellers in the numbers bar candle, is there a way to show the max buying at one point on the bar and similarly the max selling at one point on the bar?
[2023-07-11 17:29:39] |
Refer to the following: Numbers Bars: Highlight Maximum Value In For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
