Date/Time: Wed, 27 Nov 2024 00:39:53 +0000
[Programming Help] - Multiple entries with separate attached targets, but one stop to flatten all positions?
View Count: 608
[2023-07-09 03:51:16]
j4ytr4der_ - Posts: 938
I can't figure out a way to do this, not sure if it can be done but maybe someone has some ideas.
I want to be able to enter multiple times, each one as a separate trade with its own target. But I would like to have one single stop that if hit, flattens all the positions.
So far it seems that if you want separate targets for each entry, then you are stuck with either no stop, or one stop per entry. The problem with this for me, is that then the Trade Management by Study study will not move the stops all together, it will move only the nearest, or a specific OCO group.
Can what I'm looking for be accomplished natively or would this require coding something custom?
[2023-09-18 20:29:29]
User355030 - Posts: 163
I need the same functionality
@tomgilb any ideas?
[2023-10-08 15:56:24]
@scengineering
