Date/Time: Wed, 27 Nov 2024 18:42:01 +0000
Displaying TWO values side by side in subgraph
View Count: 444
[2023-07-08 19:13:29] |
TopGunTrader - Posts: 172 |
Hi, I'd like to display TWO values side by side in a subgraph. Examples would be bid volume on left in red and ask volume on right in green or as in screen shot + Delta Sum on right and -Delta Sum on left. There doesn't seem to be option for bar offset left and bar offset right. Here's screen shot of example I mocked up to show what I'm trying to do. Taking valuable data in numbers bars calculated values and plotting it to more easily see important details of whats going on. |
Capture.PNG / V - Attached On 2023-07-08 19:13:20 UTC - Size: 51.59 KB - 125 views |
[2023-07-10 08:59:31] |
Sierra_Chart Engineering - Posts: 17198 |
Yes you can do that with these Draw Styles: ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].DrawStyle DRAWSTYLE_CUSTOM_VALUE_AT_Y_LEFT_ALIGNED: For more details, refer to DRAWSTYLE_CUSTOM_VALUE_AT_Y. DRAWSTYLE_CUSTOM_VALUE_AT_Y_RIGHT_ALIGNED: For more details, refer to DRAWSTYLE_CUSTOM_VALUE_AT_Y. There are others as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-10 08:59:55
[2023-07-10 14:44:37] |
Hi, Thank you so much for reply and custom value left/right looks very cool and I can find an application for it. I was hoping to be able to draw the bar style left and right aligned. I see point, tick style, and many others but just want a regular line from value down to 0. I looked for a long time and could not find it, I suspect there is no Bar Left Aligned, Bar right Aligned right? |
[2023-07-10 16:51:09] |
John - SC Support - Posts: 36331 |
There is not a draw style to draw a line left or right aligned and down to zero. There are a few "Fill to Zero" options in the Draw Styles. Refer to the following: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-10 18:37:33] |
Ok thanks for help this explains why I could never find that option. I'm sure you guys are working on a dozen+ projects but I do believe having this draw style would be very popular. The options for how to apply it are endless, here are just a few so you realize how important this draw style is. Bid Vol left / Ask Vol Right Bid Imbalance Left / Ask Imbalance Right Volume Left / Delta Right Bid Stack 12 levels deep left / Ask Stack 12 levels deep right ES Tick Left / NQ tick right Volume/20 Day Avg Volume Left / Delta/20 Day Avg Delta Right The list is endless I realize I can use ticks or dots and text which is an amazing find but for me seeing the line is more clear. I guess I can hide variables I want plotted and use color bar based on alert condition and draw a line if ask if bigger than bid and in another alert condition show bid in transparent rectangle. Just a lot of work though and wouldn't look as clean as simply a bar left and right aligned this is mostly for those using footprints since they are wider. |
