Date/Time: Wed, 27 Nov 2024 18:43:45 +0000
Open Profit Loss
View Count: 397
[2023-07-08 14:53:59] |
77sx7 - Posts: 16 |
I see many studies available like- 'Trading: Daily Profit/Loss' 'Trading: Position Quantity' Am I missing a 'Trading: Open Profit/Loss'? I want to use these in tandem with the 'Write Bar and Study Data to File'. I see no data for Open Profit/Loss for a chart. Any help is appreciated Thank you |
[2023-07-09 07:14:44] |
Ticks - Posts: 183 |
There is a workaround that I use. 1. Add a spreadsheet study to your chart 2. Expose the "Open Profit/Loss (read-only):" value by placing this formula =J9 in column M row 3.3. Add the study "Study Subgraph Reference" to your chart. 4. Reference the spreadsheet study and select"M(SG3)". You can now use the value however you would like to. |
[2023-07-09 11:21:53] |
Sierra_Chart Engineering - Posts: 17198 |
No that is not supported. The information of that is not available historically and would not work reliably. It is not anything we would ever offer.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-09 11:21:58
[2023-07-09 11:59:15] |
77sx7 - Posts: 16 |
Sierra_Chart Engineering- Not looking for Historical information of Open Profit/Loss, just something that would export with the "write bar data' study. If I can see it on screen with a 'Trading: Profit/Loss Text' study, why doesn't it write to file? Thank you Ticks- I tried your method. However, nothing is produced in the Write Bar Data study file. I appreciate your time. Date Time Of Last Edit: 2023-07-09 12:41:18
[2023-07-09 13:37:36] |
This is because the study Trading: Profit/Loss Text does not output data to a Subgraph. You can create your own custom study to accomplish what you need. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-09 13:38:15
