Date/Time: Wed, 27 Nov 2024 18:49:48 +0000
Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance) AND blocks
View Count: 586
[2023-07-08 14:21:21] |
J DIDDY - Posts: 132 |
HI I have used your description to 'Highlight Multiple Adjacent Bid or Ask Dominant Prices (Stacked Imbalance)'...BUT I ALSO want to show them as 'until intercepted' transparent blocks with a minimum of 3 stacked levels and 300% dominant side ratio.... as suggested in this youtube video.... https://www.youtube.com/watch?v=bZWRtgHswbA The settings in both descriptions are totally different and currently I'm using 2 sets of the study (4 studies per chart, which is taking up some extra processing power) to do what I want and I'm wondering if theres a way to highlight both of these using just 1 study for bid and 1 study for ask rather than 2 for each???? Mainly to save on processing! (I enclose a screenshot of the 'Stacked Imbalance blocks' and the youtube main settings in case you dont wish to view the youtube video) Thx |
Screenshot 2023-07-08 at 15.13.15.jpg / V - Attached On 2023-07-08 14:14:57 UTC - Size: 449.97 KB - 152 views Settings.jpg / V - Attached On 2023-07-08 14:20:50 UTC - Size: 128.76 KB - 134 views |
[2023-07-10 13:58:55] |
John - SC Support - Posts: 36333 |
We are not going to view the YouTube video to see what it states, but the one thing we can say is that if you want to see the Ask and Bid separately, then you need to have 2 copies of the "Volume at Price Threshold Alert V2". We do not know exactly why you need 4 copies, but it could be possible depending on what you are doing, so we can not say, as we do not fully understand your setup.
