Date/Time: Wed, 27 Nov 2024 18:43:15 +0000
Trade Activity Log - Trades add column for accounts
View Count: 261
[2023-07-08 10:19:26] |
User687917 - Posts: 75 |
Hi Could there be a way to add a column in the "Trade Activity Log", "Trades" tab where the Account name is displayed in a single column? I know that now you can see the account name together with the symbol, but when processing data, it would be better to have the account name in a separate column, and not with the symbol. Could you add it in an update? It would also be interesting if you could join all the contracts of each symbol, for example NQH23; NQM23; NQU23... and join them all to "NQ" (the main symbol) and from here depend on the contracts. Thank you |
[2023-07-09 11:19:03] |
Sierra_Chart Engineering - Posts: 17198 |
Yes we will add a separate column for the Trade Account. We will see about the other request. This is currently supported in a chart with this setting: Chart Settings: Load Order Fills for Multiple Futures Contracts (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-09 11:19:54
[2023-07-10 09:58:13] |
Thanks i'll be expected to these improvements! Grouping contracts by symbol seems to me to be the best option to be able to better analyze the data and analyze them. |
