Date/Time: Tue, 06 Oct 2026 00:56:26 +0000
[Programming Help] - calling functions from another function
View Count: 1534
[2023-07-07 17:44:40]
WeroTrader - Posts: 46
Greetings, Sierra Chart team.
I'm trying to build a function for the SuperTrend indicator and I've run into a problem.
I already put the "#includes" for "SierraChart.h", and "SCStudyFunctions.h" and "Myfile.h" , but when I try to use the functions of "sc.MovingMedia", "sc.TrueRange", "sc. ATR" "sc.ValueFormat"; The compiler gives me an error indicating that "sc" has not been declared in this scope.
Could you give me a guide to know where I could check documentation to call the mentioned class of functions, from another function?
[2023-07-08 19:55:15]
JohnR - User831573 - Posts: 338
Have you seen this part of the docs?
ACSIL Programming Concepts: Passing ACSIL Interface Members Structure To Secondary Function
void PassingSCStrutureExampleFunction(SCStudyInterfaceRef sc)
  //The "sc" structure can be used anywhere within this function.
"An example of calling a function that receives the Sierra Chart ACSIL structure (sc)."
SCSFExport scsf_PassingSCStrutureExample(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Passing sc Structure Example Function";
    sc.StudyDescription = "An example of calling a function that receives the Sierra Chart ACSIL structure (sc).";
    return;
  // Do data processing
  // The definition of the function called below must be above this function.a
  PassingSCStrutureExampleFunction(sc);
Hope this helps,
JohnR
