Date/Time: Wed, 27 Nov 2024 18:36:39 +0000
Study Value Window
View Count: 459
[2023-07-07 17:39:22] |
User337568 - Posts: 60 |
I have been watching the Chart Values and Tool Value Window, and I want a Study Value Window for a single study. The request: Show me a chart Window of a single study. Why? I like using the Chart Values Window to check my study results. In this case, I want to know the values of one study. |
2023-07-07_12-36-02.jpg / V - Attached On 2023-07-07 17:38:30 UTC - Size: 90.74 KB - 85 views Attachment Deleted. |
[2023-07-07 18:53:02] |
John - SC Support - Posts: 36331 |
We are not certain if this will be exactly what you want, but when using the "Compact Tool Values Window" you will only see the data for the region in which the cursor is located, unless you have set the option for "Compact Tool Values Window Shows Chart Region 1 Values Only" to "Yes". Refer to the following: Chart Drawing Tools: Compact Tool Values Window Shows Chart Region 1 Values Only (Tool Settings >> Chart Values >> Chart Values) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-07 19:20:18] |
Unfortunately, the study is in Region 1 with multiple other studies.
[2023-07-10 09:08:47] |
Sierra_Chart Engineering - Posts: 17198 |
You need to use the Values Windows and customize them: Hiding Study and Main Price Graph Names and Values from the Values Windows and Region Data Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
