Date/Time: Mon, 16 Sep 2024 19:17:56 +0000
Server side Global Profit/Loss Management
View Count: 365
[2023-07-07 16:46:49] |
n8trading - Posts: 35 |
In the Global Profit/Loss Management documentation, this is mentioned: "The functionality which is documented on this page, is not recommended to be used. It was developed in response to user requests, but it cannot work reliably on the client side. This functionality is going to be moved to the Teton Order Routing Service and managed on the server side in a highly reliable environment." Has this functionality been moved to the Teton Order Routing Service and managed on the server side now? Is there a setting that needs to be enabled for this? If this is not yet available, do you have an estimated date of when it will be available? Thank you! |
[2023-07-10 16:11:51] |
Sierra_Chart Engineering - Posts: 16387 |
No we have not completed the development of this. We have only done some amount of work. There is still a lot more to do.
[2023-10-17 18:34:48] |
User624595 - Posts: 204 |
When is this expected to be tested and released on Teton?
[2023-10-17 19:40:14] |
We will do our best to resume this project, in about a week. We have gotten busy with some other things. It should only take us about a few more days.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-17 19:40:30
