Date/Time: Wed, 27 Nov 2024 19:48:29 +0000
Filling the Area between 2 study subgraphs within different studies
View Count: 352
[2023-07-07 14:58:24]
Oz - Posts: 50
I'm a little confused here.
Trying to follow the instructions as per:
Chart Studies: Filling the Area Between Two Study Subgraphs within Same Study
Note: with different studies,
however I only see one Input Study to reference in the Study Sub-graph Reference study.
Where does the other study input go? as there is input study 1 input and also input study 2 input.
Thank you.
[2023-07-07 15:09:22]
User431178 - Posts: 544
Subtle difference - it says "Add the Study Subgraphs Reference study to the chart" not "Add the Study Subgraph Reference study to the chart"
Study Subgraphs Reference has two study reference inputs, Study Subgraph Reference does not.
Date Time Of Last Edit: 2023-07-07 15:09:37
[2023-07-07 15:20:38]
Oz - Posts: 50
Found it thank you, makes sense now.
Me silly.
Cheers
[2023-07-07 18:40:44]
John - SC Support - Posts: 36344
The other thing to be aware of is that the Scale for the Study Subgraphs Reference is not set to "Automatic" by default. You will probably need to change this.
