Date/Time: Wed, 27 Nov 2024 19:40:33 +0000
Font Setting Chart Header
View Count: 285
[2023-07-07 06:16:05] |
nicktrader - Posts: 712 |
Currently the font setting for the chart header is integrated in the "Chart Text (Global)". Is it maybe possible to separate the setting for the chart header? Many thanks. Date Time Of Last Edit: 2023-07-07 06:20:51
[2023-07-07 11:59:30] |
Sierra_Chart Engineering - Posts: 17198 |
We could but there may be some complications with doing that since it does affect the height of the subregion it is located within.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-07 11:59:38
[2023-07-08 02:39:00] |
I understand. Many thanks
