Date/Time: Wed, 27 Nov 2024 19:44:24 +0000
export bars and study data to text file
View Count: 300
[2023-07-07 01:34:25]
User425645 - Posts: 113
when I have my TPO chart open and I got to "edit>>export Bars And Study Data To Text File", the text file has 0 values for every data point for the point-of-control and every column to the right of it. I would like to work with the Point of control data. Any idea why it's doing this and how to fix it? Also, all the TPO data shows up on my trading chart as expected.
imageScreenshot 2023-07-06 183157.png / V - Attached On 2023-07-07 01:33:27 UTC - Size: 224.02 KB - 74 views
[2023-07-07 13:51:50]
Sierra_Chart Engineering - Posts: 17198
That particular data for a TPO Profile Chart cannot be exported.
What you need to do is open a separate chart and use the TPO Value Area Lines study:
And then export the bar and study data from that particular chart.
