Date/Time: Wed, 27 Nov 2024 19:40:13 +0000
windows error code 32
View Count: 270
[2023-07-06 21:51:19]
ARGYRIOS MAMATSIOS - Posts: 1
i recently tried to update but having a windows error code 32..the process can not acces the file because it is being used by another process...
that s the error message so i can t get an update please help me solve this...thank you in advance
[2023-07-07 13:37:44]
John - SC Support - Posts: 36343
Make sure Sierra Chart is not running when do the update. The best option is to select "Help >> Download Current Version" which will close the running Sierra Chart and then perform the update.
Also make sure you do not have any Sub-Instances running, if you are using them.
