Date/Time: Wed, 27 Nov 2024 19:28:20 +0000
how I activate nummber bars/ How do I uppdate my account
View Count: 242
[2023-07-06 17:12:07] |
Haydar Alawini - Posts: 1 |
Hi I need to activate nummber bars service on my chart, I couldnt do it my self, I know its a 45 USD a month, can you update it to me ot tell me which packet and how upgrade my package Regards |
[2023-07-06 17:35:27] |
John - SC Support - Posts: 36341 |
We have changed your package to be Package 11, which gives you access to the Numbers Bars. You can change your package at any time by selecting the package you want in the list at the following link, and then selecting the "Update/Set" button: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#ServicePackage When you change your package, we adjust the amount of remaining Usage time available. Therefore, when going to a more expensive package, your remaining time will decrease and vice versa. If your Sierra Chart is currently running, then you may need to exit and restart in order for this change to take effect. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
