Date/Time: Wed, 27 Nov 2024 20:33:07 +0000
[Programming Help] - importig CSV file unsure of format
View Count: 316
[2023-07-06 12:31:25]
User274507 - Posts: 37
Hi, so I have a daily CSV file which is get from someone else who uses ninja. Attached is an example for ES. It gives horizontal levels that I would like to put on sierra and I'm hoping there is an easy way to import it rather than manually place each level each day. Format of the csv file attached is the ES level, label name of level and 3rd colume is colour of the horizontal level.
Is there a way i can do this? do you know what format i would need to put it in if so?
thanks
Private File
[2023-07-06 14:11:45]
John - SC Support - Posts: 36344
We do not have a way to directly import what will be "drawings" (you can import data as bars, but not drawings). You would have to develop a custom study to do this.
There is probably someone out there that already has a study that can do this. We have set this as "Programming Help", so hopefully someone will respond.
[2023-07-06 14:25:10]
User584084 - Posts: 262
Here is what I use: https://www.simplesystemtrading.com/autolevels/
Date Time Of Last Edit: 2023-07-06 14:35:33
