Date/Time: Wed, 27 Nov 2024 18:49:28 +0000
sma 200 doesnt show correct data
View Count: 346
[2023-07-06 11:15:47] |
User278398 - Posts: 291 |
hello, what i need to do to display the correct data of sma 200 as i get in interctive? regards. |
sma in siera chart.png / V - Attached On 2023-07-06 11:14:43 UTC - Size: 362.44 KB - 75 views sma in interactive.png / V - Attached On 2023-07-06 11:14:52 UTC - Size: 40.75 KB - 78 views |
[2023-07-06 14:04:48] |
John - SC Support - Posts: 36333 |
We can not answer this question as you are wanting to compare to another program. The only thing we can do is point you to how we calculate the Moving Average, which for the Moving Average - Simple, can be found at the following link: Moving Average - Simple Note that there are 27 different Moving Average studies available. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-09 08:19:26] |
if i change in the chart settings the session time, the sma study change as well.... how can i get the right sma study not depending the session time? |
[2023-07-10 14:08:24] |
The Simple Moving Average does not reset based on any of the Session Times. But, depending on how you are changing the Session Times, and how many bars are loaded in your chart and the Length of the Moving Average, you could see differences in the results. You would need to look at what you are doing and the changes you are making to determine why you are seeing something different. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
