Date/Time: Wed, 27 Nov 2024 16:54:38 +0000
how to find sprcific alert
View Count: 545
[2023-07-25 14:04:16] |
John - SC Support - Posts: 36323 |
You would have to find the alert in the Alert Manager (assuming that you have not closed the system, as the alerts are not kept) and find that particular alert within the Alert Manager and then you can go to the chart and find the alert itself to see the formula.
[2023-07-25 15:02:56] |
JohnR - User831573 - Posts: 306 |
If you are willing to go outside of SC, you can save the log to file, then open it in Excel or other SS. When opening / importing it, I selected the field separator as | Now in the SS, you can set up columns to sort by. If I remember, you can have 3 levels - sorts, within sorts , within sorts Ex - sort on Date time, within Alert Name, within Study or Chart. Just a thought, JohnR |
