Date/Time: Wed, 27 Nov 2024 19:38:00 +0000
spreadsheet data output on another study spreadsheet
View Count: 563
[2023-07-06 10:30:00] |
User185210 - Posts: 64 |
Hello, I would like to be able to have the spreadsheet study data on another study spreadsheet (displayed the same way as a regular study) when you tick "include in Spreadsheet", include in "Study summary". But it is not working as I expected and therefore, I do use another study overlay for the same graph where I want the data to be overlayed to another spreadsheet study. Is this the intended behaviour or should I proceed another way, my concern being adding to the time calculation for,I believe, no reason! Thank you for your help. Paul |
[2023-07-06 13:57:48] |
John - SC Support - Posts: 36343 |
The Spreadsheet Studies do not show the information from another Spreadsheet Study. But to get that data into another spreadsheet you have a few options. 1) Use the same Spreadsheet file, but use a different Sheet Number for the second copy of the Spreadsheet Study. Then you can reference the data from the other sheet. Refer to the following: Working with Spreadsheets: References to Other Sheets within a Spreadsheet 2) Use the "Subgraph Reference" study to get the one spreadsheet subgraph to the second spreadsheet (rather than the Study/Price Overlay). Use multiple copies of this study for each subgraph you want. You can hide these studies. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-06 14:11:48] |
Sierra_Chart Engineering - Posts: 17198 |
The Spreadsheet System/Alert Study does output data from the Spreadsheet Study. This is a configuration you can use. But apparently it is not possible, for a Spreadsheet Study to output data from another Spreadsheet Study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-07-06 14:12:05
[2023-07-06 14:41:35] |
Thank you, To John, I do use option 1 often, and option 2 is ok for few subgraphs but when you need 50 of them, it's not easy to manage but (calculation cost seems to be = 0, it's not the case with the study price overlay)! To SC Engineering: would it be possible to make it work in a future version? I use that when I want to mix different types of calculations and behaviours to the main spreasheet study in wich I have a trading spreadsheet + different regular spreasheet studies in the same and "main" spreadsheet/Trading study. Thank you. |
[2023-07-06 16:15:23] |
Sawtooth - Posts: 4120 |
The Spreadsheet Study study is the only spreadsheet study whose subgraphs can be seen by other studies. The Spreadsheet System for Trading and the Spreadsheet System/Alert studies' subgraphs cannot be seen by other studies. |
