Date/Time: Mon, 16 Sep 2024 19:11:55 +0000
No market depth on charts
View Count: 1101
[2014-07-04 14:20:50] |
User11942 - Posts: 298 |
Hello, I downloaded current version and don't receive a market depth on my charts anymore if either "Trading chart DOM on" or "Show depth" is switched on (in ver. ##1154, 1156) for any symbols. A market depth simply doesn't appear. Trading DOM and "Draw DOM graph on chart" both work OK. No prob in #1149 (another SC instance) though. What could be a possible reason for that? Pls see screen attached. Thanks. Date Time Of Last Edit: 2014-07-04 14:25:37
NQ-201409-GLOBEX [M] 15 Min #3 41824.591.png / V - Attached On 2014-07-04 14:10:57 UTC - Size: 66.98 KB - 407 views |
[2014-07-04 19:56:11] |
You need to add the Bid Size and Ask Size columns to the Chart DOM. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-07-04 19:58:48
