Date/Time: Wed, 27 Nov 2024 20:41:39 +0000
SDF Data Feed
View Count: 247
[2023-07-06 02:24:04] |
User115133 - Posts: 2 |
Hi, Do I need to connect a futures account to SC to be able to get SDF live data? |
[2023-07-06 02:25:56] |
Do I need to connect a futures account to SC to be able to get CFD live data?
[2023-07-06 03:17:08] |
Sierra_Chart Engineering - Posts: 17198 |
What is SDF? You do not need a futures account, for CFD data and the above symbol is a stock you do not need a futures account for that data either. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
