Date/Time: Wed, 27 Nov 2024 20:51:31 +0000
Trading higher position sizes with real money
View Count: 281
[2023-07-05 18:45:24] |
Jia T P R - Posts: 26 |
Hi when trading with 5 ,10 or 15 Lots can i just select that when my balance fits and hit Market entry? Is it normal that it will enter and exit with 3 or 2, 1 Lot sißes? For ex. When hitting 15 via Market that it will enter 3,3,3,3,2,1 and exit also 3,3,3,3,2,1? |
[2023-07-05 18:47:01] |
John - SC Support - Posts: 36344 |
We do not have a built-in option for determining the quantity based on the balance of your account. To do something like this, you would have to create a custom study. Refer to the information here: Automated Trading From an Advanced Custom Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-07-06 02:42:29] |
Hi John thats not what i ment, i ment when executing 15 on BUY MKT if its normal that SierraChart shows 3,3,3,3,2,1 on entering and exiting when being filled or should show 15 directly?
[2023-07-06 10:15:41] |
Sierra_Chart Engineering - Posts: 17198 |
The quantity of the individual fills is based upon what is provided by the exchange.
