Date/Time: Wed, 27 Nov 2024 20:40:35 +0000
Exchange data set for 2 computers not working
View Count: 210
[2023-07-05 13:55:09]
User812728 - Posts: 26
My Denali Exchange Data is set for 2 computers on at the same time (says 'current month') so why can i only get it on one computer. Every time I put both on, one computer says that i can only have data on one computer at a time.
Cheers
Lance
[2023-07-05 18:56:09]
John - SC Support - Posts: 36344
Right now we see zero computers connected for your account. So if you start up one system you should not have an issue.
If you do get the message, then please copy and paste the exact wording of the error you are getting, as you should be able to connect from two different computers at the same time.
